Home > Technical (L322) > beep beep beep..................beep beep beep.............. |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
Did you check small electric fan in the engine compartment ecu box (big black box with ecu's with screws on top, left of the engine).
14th May 2021 6:06am |
Definitely worth a check !!! MY 2010 5.0 SC Galway green and sand interior!!
14th May 2021 9:01am |
It may be that I have found the cause of the issue.
30th Jun 2021 9:50am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8202 |
Low coolant is just one bong and a message.....
30th Jun 2021 11:45am |
The waterpump is in but the little plastic bleed plug cracked and the new one will only arrive on Monday so looks like late departure. MY 2010 5.0 SC Galway green and sand interior!!
1st Jul 2021 8:30am |
Beep beep.... beep beep..... beep beep at start up is back with coolant level absolutely rock solid.
19th Jul 2021 8:45am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Remove the thing that beeps |
19th Jul 2021 9:01am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Have you had a look above the pedals and behind the cover for a sounder/speaker? If you haven't had the vehicle since new then a previous owner may have fitted a device.
19th Jul 2021 9:17am |
That makes more sense to be honest, some aftermarket gadget making this noise as it doesn't seem to be coming up on the screen!!! Never thought of that !!!
20th Jul 2021 8:10am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
Probably a long shot, but it’s not the battery backed sounder is it?
20th Jul 2021 5:01pm |
Hi Chris, thanks for that. Did you get any lights or indications on the dash or anywhere with that ?? MY 2010 5.0 SC Galway green and sand interior!!
22nd Jul 2021 9:18am |
Hi
22nd Jul 2021 4:30pm |
Thanks, will keep you all posted on progress!!! MY 2010 5.0 SC Galway green and sand interior!!
23rd Jul 2021 8:56am |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
I know you said your beep is coming from the dash somewhere but in case someone else comes here looking for a beeping sound, mine started doing this and it turned out to be the rear entertainment remote. I have absolutely no idea why, it was beeping and then briefly flashing something at the top of the screen (no idea what is it just blinks up for a split second and then dissapears, repeating every few seconds).
25th Jul 2021 9:22pm |
