Home > Technical (L322) > Battery connections
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Battery connections
Have recently replaced the battery and I've noticed that the connections are not as secure as I'd like i.e. they rotate. so question is can you replace these with the old fashioned clamp type?
Also I note that there are a lot of connections bunched up (I assume this is standard) but if I get the clamp type could all the extra connections be moved to the jump start post instead leaving only one thick cable on the actual battery terminal?
Cheers
Post #594158 13th May 2021 3:57pm
Merchy
Might be worth a photo, then there will be members on here who can tell you if it standard, with just a glance.
Post #594160 13th May 2021 4:08pm
