Home > Technical (L322) > Tow hitch circuit breaker
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi everyone,
had a labour intensive weekend Laughing
Did rust repairs and i stalled a Westfalia tow hitch!
Short question, as I bought one from the scrap yard - is there a need for a circuit braker?
thank you 🙋🏼‍♂️
[/img]
Post #593875 11th May 2021 2:02pm
No, the wiring should just plug into a module in the right hand boot cubby, the module for the trailer on a 2004 is a box about the size of a packet of cigarettes. If you have a genuine harness then this should just be plug and play, plus a bit of telling the CCf there is a to leave fitted. There is nothing that can't be fixed with a hammer😜😜
Post #593887 11th May 2021 4:17pm
hbthepilot
Thank you - that’s what I did - it fitted right next to the circuit break in the boot!
However Rave says that there are a few breakers that need to be added!
CCF programming necessary on a ‘04? Thought it was only necessary from 2010 onwards!
Cheers
Post #593888 11th May 2021 4:19pm
It’s a grey area.... if it works I wouldn’t worry.... There is nothing that can't be fixed with a hammer😜😜
Post #593892 11th May 2021 4:51pm
hbthepilot
Haven’t tried it yet! Just wanted to make sure to take fuses with me when I will pick up the trailer!
IID Tool I have with me anyway - so I’ll double check if it recognises the trailer ECU!
Any other instructions when installing the original 7-pin kit?
Cheers
Post #593893 11th May 2021 5:02pm
