Home > Maintenance & Mods (L322) > Turbo actuator access |
RNHobbs Member Since: 28 Dec 2019 Location: Wales Posts: 1 |
I know this is an older thread, but it is a useful one and still relevant. I’m new to the forum but far from new to Land Rovers!
29th Dec 2019 7:43pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I wonder if this will cure my restricted performance fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
30th Dec 2019 5:44pm |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Hi Richard, yep very useful had a sized actuator on my L322. Followed your advice and all sorted. Was lucky enough to have the use of a ramp so it made it a lot easier to get at the left side. |
1st Feb 2021 5:03pm |
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 |
Had the same problem - P132E code - stuck turbo actuator. A local LR specialist failed on this one. TBH it was clear when I took it in that they just couldn't be bothered with it. Very disappointing for a garage well known in the area.
6th May 2021 12:40pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 |
Hi, I had the same issue with my 3.6 not long after buying it, came up with restricted performance so took it to a local indie with a good reputation here in the North. He confirmed the actuator was stuck but said he would free the stick one and clean up the other. He had the car for 1 day and the charge was only £66 plus VAT, had no problems with it since and that was a couple of years ago. He said it is a pain to do but did say it’s something you can do yourself when you know what your looking for. He said it often happens if the car isn’t used much which at the time it wasn’t. |
6th May 2021 8:08pm |
You have a very good indie there and a bargain price. I have a cheap OBD scanner and found the code, which I reported to my indie. Not only did they not do the job, they also charged me £55+VAT to scan the fault I'd already told them about. I had a list of jobs I asked them to look at, but only if they could free off the actuator. They didn't succeed. But they did change the oil & filter, which is a bit like having your nails done when your problem is a broken arm! They also managed to check the o/s actuator that was easy to get to, which wasn't stuck. They reported that it was free, so the turbo may be toast. It's not.
7th May 2021 12:30pm |
Aylmer Motorworks http://www.aylmer.co.uk
13th May 2021 8:33pm |
RRluvva Member Since: 15 Oct 2019 Location: Fife Posts: 6 |
Firstly a big thanks to RNHobbs post for his description of access it helped big time and got my good friend to locate it as I couldn't find it. Once I found it I had a 5mm diameter solid rod I bought from BQ for £4 which really helped and RNHobbs is spot on with the circa 18inch legnth. I had a modified flexible bucket handle but there was too much play in it. Once you locate it get the rod on it (post lathering with penetrant) and get movement on it. It's so fiddly but just persevere and get your line of sight. It's easier to push it up at first and then try and get it back down. I'd reccomend a slim (pen size) line torch as once you see it and put the rod in the gap your line of sight gets blocked. Hope the photos help - click my gallery to see them. 3.6 TDV8 - on probation
11th Dec 2022 7:35pm |
GFWC Member Since: 16 Mar 2024 Location: Kent Posts: 4 |
Hey guys, I’m having the exact same issue. Was told by the garage that I usually use that it needed a turbo replacement as the passenger side turbo actuator is seized.
16th Mar 2024 12:12pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1222 |
Is yours the 4.4 diesel? If so, get yourself in a position to see the actuator and get someone to start the engine. On start up you should see the actuator move the rod a couple of times by alot more than 2mm. |
16th Mar 2024 12:23pm |
No mine is the 3.6 v8 or 3.7 can never remember.
16th Mar 2024 1:07pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Does the actuator move on ignition on or engine start? Anyone got a video of it moving? |
20th Mar 2024 7:43pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 55 |
The actuator on the right hand/ primary turbo on the 4.4 tdv8 cycles through its movement by just turning the ignition on and off. No need to start the engine. I know because I recently checked mine. |
20th Mar 2024 8:17pm |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
Old thread, but as relevant as ever!
10th Jun 2024 8:04am |
