Home > Technical (L322) > IID Tool - Looking for 2 bits of code
garyRR
I'm looking to see if there's code available for the following:
1. Unlock on ignition off / removal of Key from ignition
Just like the car locks all doors above 10mph, to unlock all when the key is removed so that I don't have to pull my door handle twice!
2. "Delete" Auto windscreen wipers so they can operate manually
I have an aftermarket windscreen and the sensor works intermittently at best. For the headlights, if they don't come on, it's no real issue, as I can turn them on manually. For the windscreen wipers, I either have to have them "on" or "off", as the intermittent settings are linked in with what the sensor detects. I want to see if there's a way of telling the car there is no Auto wipers so that I can use the intermittent settings manually. 2015 Range Rover Autobiography 4.4 SDV8
Post #593321 6th May 2021 1:04am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
You're probably best to email gapteam@gap-diagnostic.com and ask them direct.
Cheers,
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #593342 6th May 2021 9:57am
#1 isnt possible..
#2 you can switch off the rain sensor in the bcm menu. ... - .- -.
Post #593343 6th May 2021 10:00am
What Stan says...
More than likely there is no fault with the windscreen, either the fitters don't fit them properly or have damaged it when swapping it to the new screen, they have a jell like membrane that sticks to the glass, this gets hard over time and is easily broken. If the screen was fitted recently then take it back, no reason it shouldn't work, if it is the screen then they still need to fix it and replace with a screen that does work...! Pete
Post #593346 6th May 2021 10:45am
p38arover
Australia
My rain sensor didn’t work properly after a windscreen replacement. ThenI found from the Faultmate docs that I needed to do a sensor recalibration. I did that and all is good. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #593350 6th May 2021 11:19am
