![]() | Home > My Range Rover > Dommo's L322 4.2 Supercharged |
Dommo Member Since: 25 Feb 2021 Location: Swindon Posts: 26 ![]() ![]() ![]() |
A couple more little jobs found today, suspect this will be the gift that keeps on giving. There's a cover missing from the rear passenger ashtray and the passenger side boot strap for the tailgate is missing, looks like it was rusty and the fitting snapped when someone was trying to remove it for good measure.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Looks nice mate.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
very nice have fun |
Ah do they slot spanners in there to undo the bolts? Sounds like a "whilst you're there" kind of job ![]() |
So far so good I think. No bubbles, but a light bit of orange that I'll get treated before it becomes a problem. The underneath seems to have had the attention of some underseal, but I'm not sure the bits that have rust anyway. I'll not have a proper look until I fit the tow bar armature. |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
Mine was the same. One side easy-ish, with an impact driver and big bar but on the other side, I had to drill it out. A real PITA! 2005 FFRR SC Java Black with Overfinch Exhaust (UK) 2008 D3 HSE Stornoway Grey (UK) 2008 D3 HSE Izmir Blue (ZA/Zimbabwe) 1995 D1 300 Tdi (Zimbabwe) |
The other side is brand new (I'm sure I checked it when viewing the car but clearly not!), so think it's the same.
Also had lots of faults because of the battery reading low, 11.3-11.5volts.
Sounds like we're on the same path. The battery doesn't look too old so I'll give it a chance on the CTEK before condemning it |
