Home > Technical (L322) > Funny air noise |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Funny enough, yes, on Saturday on the motorway I got the same noise only for about 5 sec, haven't heard it before and hasn't done it since, I thought it might have been the top section of the drivers door seal as it needs a new clip from when it froze to the bodywork and got pulled off when it was below freezing around Christmas time 2006 Mercedes CLS
7th Apr 2011 11:59am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Sounds like the Fuel Burning Heater to me. Discovery 4 HSE
7th Apr 2011 12:18pm |
LOL, I had the same issue a while back. Mine turned out to be a combination of a rag and a 1L can of oil wedged in with the battery. If there's anything in that space other than the battery it whistles big time.
7th Apr 2011 12:20pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
I have had the same experience! Sounds exactly as you describe - blowing over the top of a bottle - seems to come from under the steering wheel. Seems to happen only when cruising on the highway, perhaps twice to three times an hour. I don't have the FBH, so it can't be that. mentioned it to the dealer, but they can't even sort out a squeaky front suspension.... |
7th Apr 2011 12:52pm |
The scuttle panel can lift around 50-60 seems to be its "sweet spot" |
7th Apr 2011 1:13pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
windscreen washer pipes vibrating on the scuttle near battery also causes a similar noise at 70ish |
7th Apr 2011 1:18pm |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 |
Hmmm! The battery was replaced too, I wonder if the washer pipes were disturbed... |
7th Apr 2011 2:20pm |
thats exactly what mine did after the battery was replaced!
7th Apr 2011 2:38pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Sorry, not adding anything useful just find it really funny how we're driving our very own orchestras depending on how fast you go/how sh4gged out the car is!
7th Apr 2011 2:39pm |
it was the peasants at my battery depot that goosed mine |
7th Apr 2011 2:56pm |
How did you fix? Off with the scuttle, new tape and back on? |
7th Apr 2011 3:12pm |
It was just before Christmas I replaced my battery, I've probably arsed something up, I'll check it later. 2006 Mercedes CLS
7th Apr 2011 3:20pm |
heat gun, very very gently did the trick - seemed to reactivate the sticky - and pushed back down hard |
7th Apr 2011 3:41pm |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
I dont think scuttle is glued down |
7th Apr 2011 8:01pm |
