Home > Maintenance & Mods (L322) > Do you use Super + unleaded in your Supercharged..?
Page 1 of 3 123>
I'm having an argument with my mate who is an ECU reprogrammer.
He says I should use Super+ unleaded in it, I say 95 octane is fine, that's what it says in the handbook...
I do get occasional light engine knock on light throttle in a high gear with 95....
If you do use Super+, have you noticed any difference, and do you use 97 or 99 octane...
Thumbs Up Pete
Post #592667 29th Apr 2021 12:29pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
I use Momentum 99 in my 4.2 SC and am approaching 170,000m. When the spark plugs were changed at the recommended 110,000m they looked like they had only done a few thousand miles & didn’t need changing, so I’ve kept the old ones as spares just in case.
I think it’s well worth the extra few pence a litre Thumbs Up
Post #592670 29th Apr 2021 12:59pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Always use use Shell V-Power Premium in my 4.2 SC Thumbs Up, never used anything else so cant compare.
NB: The mower seems to like it as well.
Post #592682 29th Apr 2021 1:51pm
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
TBH honest, I use both.
That's partly because I either forget or end up at a pump that doesn't have!!
My Audi TT used to play up if I didn't put in the higher octane fuel in it but to date, with the SC, I haven't really noticed a difference! 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #592691 29th Apr 2021 2:31pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Tesco cheepest all the way pete Rolling with laughter
Post #592713 29th Apr 2021 7:34pm
=dj=
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
I’ve only covered 1k so far in my 5.0 SC, but have been running it exclusively on V-power.
An ECU should adjust according to the quality of the fuel, so 95 will be fine - but I choose to run super so the ECU doesn’t dial anything back (and also for the additives that hopefully keep valves cleaner etc).
I ran a Subaru Legacy 3.0 for 10 years previously - super or normal made no difference whatsoever, but it was a normally aspirated engine. I also have a 200SX which hates normal unleaded (down on power and mpg) but admittedly that is mapped to V-power so is perhaps not a reliable witness Wink
My thinking is super probably benefits forced induction engines more...?
Post #592720 29th Apr 2021 9:36pm
Thanks guys... seems to be quick enough on 95 octane for me, I saw some super + the other day at 30p per ltr more than 95....!!! £30 extra a tankful doesn't seem worth it to me..... Thumbs Up Pete
Post #592725 29th Apr 2021 10:35pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Shell Super in both mine Thumbs Up Thumbs Up
Post #592728 29th Apr 2021 10:59pm
V-Power for me. Its one of those marginal things - its probably tiny, but the engine will be faster with better fuel. If that wasn't important to me I wouldn't have the most powerful version available. Seems daft to spend a fortune on buying the highest potential then reigning it in to save a few £ at the pumps. Noted that some garages take the pish and have a huge differential...but most are around 12p/liter so maybe a tenner per fill from empty. Also agree above about some value in the extra additives/cleaners although only likely to make a difference over a longer period of ownership. Its been good in my other cars even from Optimax days and I've had one of them over 30 years another over 18 etc.. Mike - MPx
Post #592734 30th Apr 2021 12:02am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
20k miles since I bought it and always use regular unleaded. Drives like a dream and plenty of go.
If regular was good enough for my 911, it's good enough for the S/c. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #592736 30th Apr 2021 5:15am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Super+ only...Preferably Shell V-Power...I used it currently in the 5.0SC, the M2c and the old MK2 GTI. Same as in the AMG's we've had. And the Golf R that I used to race was terrible on lower grade, heck couldn't even trust Tesco Momentum due to lack of consistency.
Super+ Shell V-Power all the way...
Post #592739 30th Apr 2021 6:15am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Sainsbury's bog standard is good enough for me🙂. Used it for the last 8 years and 40,000 miles. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #592770 30th Apr 2021 12:27pm
DrF
Super and V Power for mine Thumbs Up Thumbs Up
Post #592779 30th Apr 2021 1:48pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Regular 95 octane for my 4.2 SC and there’s never been a hint of pinking.
I may well end up using V-Power or similar just to avoid the extra ethanol Censored they’re going to start slapping into regular petrol. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #592793 30th Apr 2021 3:57pm
Interestingly the largest market for the S/C, the USA, has the worst petrol, they have Regular at 87, Midgrade from 89-90 and Premium from 91-94 so even their top octane is lower than our standard petrol.....!! Pete
Post #592794 30th Apr 2021 4:12pm
Page 1 of 3 123>
