![]() | Home > Wheels & Tyres > Tires for road and soft sand beach |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
Plenty of folks run 255/55/20 on the 322, they are the standard fit on the 405 so folks bought the 405 alloys with the tyres and put them on the 322.
hamiamham Member Since: 28 Apr 2021 Location: Nantucket Posts: 13 ![]() ![]() ![]() |
Thanks for that. Any tires you can recommend? |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
32" seems to be the biggest practical diameter. Even then you might get rubbing at full lock / articulation. Rubbing is increased if you go wider for obvious reasons.
I am going to order a 18" rim and have the mechanic test fit to my car. Assuming it fits I will have a number of tire choices. If it does not fit, I will go with a 19" wheel which - while not ideal - does allow me more side wall height with the same tire diameter. My air suspension has given out on me in the past so I would like to avoid the bump stop issue if I can. |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
I am sure the only 18" that will fit over a supercharger brembos is the one made by Compomotive, I may be wrong and you may have different options over there |
Pretty sure rosco is correct in his thinking.
