Home > Technical (L322) > Trickle charger |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
During last year's lockdown my car was hardly used, so I bought an adaptor from the Forum shop (see above) and plugged an Optimate trickle charger (originally acquired for use with a motorcycle that is used only when there is no salt on the roads) in to the towing electrics. It was very easy and convenient, especially as I cannot open the bonnet when the car is inside the garage. If you have towing electrics that would seem the best solution. There are other kinds of chargers, I think others on here use CTEK, you'll see the kinds catered for by the adaptors on the shop page.
22nd Apr 2021 6:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
It’s all because of the emissions. If it’s not having load from the alternator when cold it’s better for polar bears.... I think.... it only charges to 80% anyway I believe, on the 4.4 TDV8 anyway.....
22nd Apr 2021 8:27pm |
Upnorth Member Since: 13 Mar 2021 Location: Orkney Posts: 24 |
Thanks, I don’t have towing electrics yet so will put a socket under bonnet and connect trickle charger to that. |
23rd Apr 2021 5:37pm |
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 |
By far the best. Neat plug so easy daily use.
23rd Apr 2021 7:35pm |
