Home > Technical (L322) > HELP air suspension errors TD6
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi all
Today I gave my compressor a much needed overhaul...
New piston kit as well as some new beads in the air dryer filter.
Had some help from our friendly assistant...youtube. Very Happy
After getting it all back together and refitting into car I,m now getting
heap of errors. Big Cry
IID tool errors are:
0X8 High Pressure Exhaust Valve fault
18 Exhaust Valve Supply Fault
0X24 Compressor Temp Sensor fault
0X7 Exhauslt Valve fault
076 Reservoir Pressure Drops when filling
Any help getting my beast back to normal greatly appreciated.
btw, always park it in access mode, so backside is miles high,front is as low as she will go. Big Cry
littlecub
Post #591179 14th Apr 2021 8:17am
Merchy
My best guess at this one is -
If you did not have these faults prior to the comp over haul, is that you may have made a mistake during said work. Easy thing to do.Seems like a bit of a coincidence.
No offence meant, I am a marine engineer of advanced years Whistle . and know full well, we ALL make the odd booboo.
Post #591183 14th Apr 2021 8:44am
A wild guess but that lot sounds like it's trying to suck air out of the system and inflate the world...!!!
I can't remember on your model but can you get the inlet and outlet the wrong way round...!!
I take it you have tried to reset the system with the IID Thumbs Up Pete
Post #591206 14th Apr 2021 11:30am
littlecub
Hi Hylands
How do you reset with the IID tool
littlecub
Post #591256 14th Apr 2021 7:10pm
Can't remember off hand, there is a setting in there somewhere, read through the user manual...
Can you swap the inlet and exhaust, or are they different..?? Pete
Post #591257 14th Apr 2021 8:04pm
littlecub
me thinks there different as there are 2 different size hoses.
If I could find a schemantic of the where the hoses go,that will help,
as I,ve looked on the web and cant find anything.
Also I,ve been out pulling it apart again and putting it back in.
Same codes as before but at least the arse end is stuck up in the air anymore.
Think there both on transport mode now.
I,ll have to find the GAP handbook that I downloaded ages ago and go thru that as the next step.
I was hoping to fix it this morning as I have a hospital appt later in the morning and its a 3/4 hr drive to get there.
Instead I have a early toyota rav manual to drive with a Censored gearbox. Whistle
Post #591264 14th Apr 2021 10:30pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
When I reconditioned the compressor on my VSE a few years ago it failed within a couple of weeks forcing me to do the job again. I seem to remember it giving me similar fault codes at the time.
Seeing no obvious reason why it should have given up again so soon I stripped the compressor parts down a little further than normally required to investigate what I may have done wrong and in the process discovered a tiny little wadding filter, probably about 4mm in diameter, which if I remember correctly was somewhere near the exhaust air exit side of things. This filter had become blocked with what seemed like dust and particles from the original piston seal breaking down.
As I had replaced the desiccant in the drier unit for the compressor at the same time I had the old 2” filter discs which fit inside there available and managed to fabricate a replacement one using a clean piece of one of them.
It was fiddly to cut such a small piece but once all replaced it cured all my issues.
Sorry I can’t be more specific about it’s location but it was a few years ago now. Should have taken pictures in hindsight. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #591270 15th Apr 2021 6:03am
littlecub
Having pulled it apart quite a few times its now on the bump stops. Big Cry
The compressor loses air as its trying to fill. Big Cry
Talking to an indy he said that he doesnt refurb them,he just puts a new one in. Censored
Have ordered new one from UK and also the relay.
Question
Where does the relay go....
There is 3 yellow and one black relay in the rear fuse box area, is this where it goes above the fuses.
According to Rave, there is only 2 fuses, one in the front and a 50a fuse in the rear( both are good)
TIA
littlecub
Post #591482 16th Apr 2021 9:19pm
littlecub
Can anyone tell me where the Fuse YWB101300 goes.
Its for the air compressor on a 2003 TD6.
I have 2 versions of RAVE and neither of then shows where it goes.
TIA
littlecub
Post #591660 18th Apr 2021 8:07pm
littlecub
Sorry its the relay.
Post #591780 19th Apr 2021 7:44pm
Merchy
https://fusesdiagram.com/range-rover/fuses...-2012.html
Try this, this was all I could find on the net, do not know if applicable to your car, mines a 2006, but do not know some of the differences. Have tried to look in wiki, but cannot download some of the info from some links - my laptop is almost as old as me Whistle
Edit - also shows relays.
Post #591784 19th Apr 2021 7:59pm
littlecub
Thanks Merchy. Bow down Bow down Very Happy
Just what I,m looking for.
Thanks once again.
littlecub
Post #591919 20th Apr 2021 7:09pm
Merchy
G'Day Littlecub
No wurries mate Rolling with laughter
Hope that is the right info and that all is now OK.
Looked up your place on the net, nice place to be, been to Aussie quite a few times and been through the Bass Strait a few years ago, when I worked on Cape size Bulkers carrying iron ore / coal, that bit of sea can get VERY interesting, VERY quickly, the ferry crossing must be interesting in winter Thumbs Up
Post #591939 20th Apr 2021 8:19pm
littlecub
Hi Merchy,
Yeah that link is great.
Yes Bass Straight can get very interesting at times,I have been crossing in 3-4mtr
swells as well as dead calm. Summer is worse than winter for the large swells,more of them,
but it depends on what the weather is doing in the rest of the country ie, el nino or la nina (drought or flooding rains).
The Tas govt here is supposed to be signing off on new ferries but who knows when that will be.
We were getting them built somewhere in Europe,but when the pandemic hit they canned it and
havent signed a contract since.
Maybe after our state election early May they might just pull there finger out and sign a contract.
Take care
littlecub
Post #591978 21st Apr 2021 9:51am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
A video tutorial... https://www.youtube.com/watch?v=c4Pnlp164-E 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #592085 22nd Apr 2021 7:41am
