Home > Maintenance & Mods (L322) > Battery for TDV8
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Battery for TDV8
Just got back from GSF after my battery gave up yesterday £119 for this
Would this be the right one looks to cheap
Post #591848 20th Apr 2021 10:53am
Baltic Blue
Make sure it is an AGM type battery.
It doesn’t look right to me.
Post #591849 20th Apr 2021 10:58am
Simran0211
It does say AGM type battery and I did ask before parting with the 💰
Post #591851 20th Apr 2021 11:21am
dingg1
I'd double check that, yuasa agm are usually black and not silver, they may have changed recently but that was the case in the past.
Post #591853 20th Apr 2021 11:39am
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I'm happy to be corrected, but I don't believe that the Yuasa YBX is an AGM Battery. The specification sheet for that battery states: Technology Ca/Ca
Calcium batteries are the most commonly fitted battery; they also go by the name of 'wet lead acid' batteries. The basic ingredients are no different to the old style, but these batteries are more durable and have more starting power. They have a good shelf life and are maintenance free.
Wiki States: Silver calcium batteries generally require more charging voltage (14.4 to 14.8 V) and deteriorate rapidly in vehicles which do not provide the required voltage range. (Alternators) which never reach required voltage range will cause rapid sulfation due to battery never being charged fully. As a general rule, silver-calcium batteries should not be installed to vehicles or systems which are not specifically designed for silver calcium battery chemistry.[citation needed] This also may occur with static chargers, some of which fail to charge these batteries. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #591854 20th Apr 2021 11:49am
Simran0211
Big Cry Doesn’t look good
Post #591856 20th Apr 2021 12:00pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I've got exactly the same battery in mine. Fitted by the previous owner. I've got the receipt that says it was fitted 3 years ago. Touch wood no problems so far for me.
Post #591862 20th Apr 2021 12:21pm
PeteT80
This I what I fitted in mine, same as original battery apart from JLR stickers.
https://www.tayna.co.uk/car-batteries/varta/g14/
Post #591867 20th Apr 2021 1:48pm
DrRob
No mention of AGM
https://www.yuasa.co.uk/ybx5019.html
Take it back I would Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591874 20th Apr 2021 2:37pm
DrRob
https://advancedbatterysupplies.co.uk/product/varta-g14/
https://www.fullfatrr.com/forum/topic43662.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591875 20th Apr 2021 2:41pm
Simran0211
Thankyou all Thumbs Up
Post #591940 20th Apr 2021 8:19pm
