Home > Technical (L322) > PDC Functionality - Not your usual symptoms. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hi there
12th Feb 2021 10:05pm |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Hello matey, first and foremost, establish if you actually have a problem to begin with. If you start the car and leave it in park, the PDC should remain off. If you select drive it should also remain off. It’s only if you select reverse the system will be activated (automatically). If you then shif out if reverse and then into drive the system will remain active until you’ve reached about 8mph when it then deactivates, but you have to have either selected reverse first or activated it manually for the system to be live. If you go from park to drive the system will remain off until you do either of the above. The reason being is if it was permanently live it’d drive you mad every time you’re in a queue of traffic.
13th Feb 2021 12:12pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
Mine is an 04 plate and works same as above. |
13th Feb 2021 11:27pm |
capesthorne Member Since: 12 Jan 2020 Location: Sunbury-on-Thames Posts: 11 |
Thanks all for your responses and apologies for the delay in getting back to you.
18th Apr 2021 6:49pm |
