Home > Technical (L405) > MY18 L405 P0047 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
make sure the fault code is showing when it goes to the dealer. If it has LR warranty then it should also come with LR assist. it may be worth a call to them when the light comes on, they might send a chap out (possibly AA) who can read and log the code and possibly get it into a dealer a bit sooner? There is nothing that can't be fixed with a hammer😜😜
16th Apr 2021 6:58pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1145 |
Thanks northernmonkeyjones
16th Apr 2021 7:18pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 703 |
Kot, what gadget are you using to reset the code? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
16th Apr 2021 8:08pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 214 |
From experience of the same symptoms it is most likely that the turbo actuator is faulty, caused by oil tracking through the wiring harness from the oil level sensor to the actuator.
17th Apr 2021 7:51am |
ilard
17th Apr 2021 9:05am |
Fifth Horseman
17th Apr 2021 9:10am |
im not sure if the 2018 models are prone to this failure as the updated part has been available for some time and I would assume at some point they started fitting it as standard, but as you are under warranty, if it needs doing it should be FOC for the wiring harness upgrade as part of the campaign and they should then fix the actuator under warranty so you should be covered for everything. There is nothing that can't be fixed with a hammer😜😜
17th Apr 2021 12:04pm |
It should show if it hasn't been done. There is an associated tech bulletin for this fault - LTB01087v4 |
17th Apr 2021 6:31pm |
It did show on the online service record as well. But I think they have changed that...... that’s how I noticed it needed doing on mine. There is nothing that can't be fixed with a hammer😜😜
17th Apr 2021 6:56pm |
Well it didn't show up on any campaign i can see, as I subscribed to Topix to get more workshop info it shows nothing outstanding. So was there no recall? are they just waiting for owners to show a problem that is inevitable and then repairing as and when? Something that could be added to a service appointment. I have only had the car 4 weeks surely this should have been done before re-sold? They sure know how to off their customer base dont they.
24th Apr 2021 10:20pm |
So it was an internal failure of the turbo actuator according to the paperwork, nothing mentioned about N375 but suspect that was the case. This car has only 10k on the clock and the LR assist guy mentioned its never had enough run time with a hot Engine for capillary action to show up the fault until now.
27th Apr 2021 1:21pm |
LR assist is sometimes the way to go with faults if you have a warranty. Especially if they throw a code and a warning, as they can usually get a priority booking with the dealer and hire car, plus they are there standing next to you on the drive so you can make sure they are doing a decent job of diagnosing the issue, glad it seems to have been sorted. Also the fault is then logged with LR and the warranty company, so no flannel from the dealers who just want to charge as many people £££ for oil changes and not fill the ramp up with an actual issue! There is nothing that can't be fixed with a hammer😜😜
27th Apr 2021 5:43pm |
Afernandez Member Since: 15 Jul 2021 Location: Mendoza Posts: 2 |
Many thanks for that!, same problem in Chile… |
15th Jul 2021 10:27pm |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
10k miles on the clock for diesel and a 2018... you have the wrong vehicle.
16th Jul 2021 9:57am |
