Home > Technical (L322) > L322 3.0 Ltrs Vogue 2006 - Anti Roll bar rear bushes.
chicrange
United Kingdom 2006 Range Rover SE Td6 Adriatic Blue
Hi Folks, need some help!
I decided to change all the Anti Roll Bar bushes and links, front and rear and bought the Delphie Brand and the bushes I went for were the Mehiel, German Brand.
When we came to fit the Bushes on the rear links they were too big. The ones they sent 26.5mm and the Anti Roll bar Bushes we need are 22.5mm Apparently the same on the:
DISCOVERY 3 NEW REAR ANTI ROLL BAR D BUSHES (X2) BUSH SET - LR015336
DOes this make sense? Called the LR dealer and as usual 0% help! They said that my model for the year where different and the came out with the 22.5mm bushes! And surprise surprise they do not sell "just" the bushes, they come with the whole arm at a whopping £174.00 + vat!
Any Take on this! Wanted to put some hard core polythen material on them.
Post #591410 16th Apr 2021 10:51am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
The OE bushes are bonded directly onto the ARB to eliminate noises.
So you won't be able to buy OE replacements apart from the whole assy.
You'll probably have to cut all the remnants of the old rubber bushes off to fit the aftermarket parts.
Aftermarket is always a challenge to get the correct spec. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #591412 16th Apr 2021 11:34am
