Home > Technical (L322) > Burning Rubber smell - Calipers??
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
SWMBO has been complaining about a burning rubber smell when she tows the horses (c.2.8 Tonne). I have never smelt it so as usual, ignored her, however I went showjumping with her this morning and low and behold burning rubber smell and both rear wheels were toasty hot, now I have searched as thought sticking caliper however only happens when towing?? Any bright ideas esteemed members, I thank you Thumbs Up
Post #591312 15th Apr 2021 2:41pm
kevinp
If your horsebox has a high nose weight it could be the tyres overheating. Do you increase the pressure before towing? If your calipers are at fault the discs usually have a blue tinge to them.
Post #591315 15th Apr 2021 3:17pm
Rosco
Thanks Kevin, would that account for the wheel being hot as well? Thumbs Up
Post #591317 15th Apr 2021 3:31pm
she probably had the hand brake on Rosco.. Mr. Green
check them calipers are free and working ok. ... - .- -.
Post #591321 15th Apr 2021 3:49pm
Rosco
Stan. would concur however we have never used the handbrake on this one (may be half the problem), only happens when towing is my conundrum Thumbs Up
Post #591322 15th Apr 2021 3:55pm
kevinp
I tow a 2 ton caravan and the rear tyres get quite hot which radiate heat that makes the wheels quite warm to the touch. If your wheels are getting to hot to touch then I would suspect that your rear brakes are binding.
Post #591329 15th Apr 2021 5:06pm
Merchy
Two points to add to the above already mentioned -
Recently my rear brake callipers seized, thus brakes were binding, the heat that went into the wheels and tyres was an education, and that was driving gently to get home to fix the issue, and that was without enough heat to see any blue colour on the discs. Enough heat to burn my bloody fingers though.
Is the trailer braking system working? Horse boxes I have towed had the trailer axles braking system, if this isn't working this will put extra stress on the car's brakes.
So far in this house, daughter - various injuries, grand daughter - broken arm, me - two broken ribs, oh and years back my mother had concussion and hospital visits, all from coming off horses, it seems you have the right idea Rosco Stay at home. Rolling with laughter Thumbs Up
Post #591332 15th Apr 2021 5:49pm
Rosco
now that makes sense Merchy, I will investigate, thanks Thumbs Up
Post #591333 15th Apr 2021 5:56pm
CS
Just to add to others' comments, the 322 braking system only uses the rear calipers when the car is heavily loaded or when towing, and they are prone to seizure, mine had to be freed off every year after maybe year two, so sticking rear calipers would be my first port of call. Only Range Rovers since 1988
Post #591339 15th Apr 2021 7:00pm
dingg1
You sure about that cs?
Post #591340 15th Apr 2021 7:14pm
dingg1
I mean rear braking just utilised when towing or heavily loaded
Post #591341 15th Apr 2021 7:16pm
Rosco
CS, I have been towing with L322s for 16 years and never had this issue, could the car not be seeing the trailer ? First one I have had when the reverse sensors keep going once hooked up. think I am answering my own question Rolling with laughter
Post #591342 15th Apr 2021 7:17pm
CS
OK, what I should have said was that the 322 mainly uses the front brakes, and the rear calipers come into use to a greater extent only when braking hard or there is extra load including from a trailer.
See owner manual under "Electronic brake force distribution". Only Range Rovers since 1988
Post #591359 15th Apr 2021 8:59pm
Merchy
An additional thought Rosco, I would imagine that your better half drives the way I do when towing horses, 'driving gently' with no harsh braking etc, so I would definitely check out the rear callipers AND the trailer brake system ASAP
Trailer mechanical maintenance is something many people don't think about - No offence intended - the UK is one of very few countries in Europe now that does not require an MOT for trailers / horse boxes - which shows how far behind we are in some ways. From past experience, on the yard I go to, most horse trailers I see are parked up after use and immediately forgotten, out of sight / out of mind.
Post #591376 16th Apr 2021 12:54am
Rosco
Update , sort of !! The car is not recognising that it has a trailer attached due to the LED lights apparently, I need a resistor. Question if it doesn't recognise it has a trailer attached, will that mean the trailer brakes won't work, car brakes have been checked and all good, trailer brakes work OK independently from car, .... any hapl appreciated Thumbs Up
Post #594378 16th May 2021 12:28pm
