Home > In Car Electronics (L405) > Road speed sign
Bg259
Road speed sign
Does anyone know how to activate the road speed sign on a 2019 Vogue . I want the icon which shows you the current road speed.
Post #591265 14th Apr 2021 10:52pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
From the manual:
Use the controls mounted on the left side of the steering wheel to display and navigate through the instrument panel menus.
Operate the instrument panel menus as follows:
1. MENU button: Press and release to display the instrument panel menus. The instrument panel displays the menu list. The MENU button extinguishes and the OK button illuminates.
The MENU button does not illuminate if the instrument panel displays any warning or information messages. In this event, the OK button illuminates instead of the MENU button. Press the OK button to clear each message after reading and taking any required action.
2. Operate the buttons as follows:
• OK button: Press and release to select a highlighted menu item.
• ∧ button: Press and release, or press and hold, to scroll up a menu list to highlight the required menu.
• ∨ button: Press and release, or press and hold, to scroll down a menu list to highlight the required menu.
• > button: Press and release to view the sub-list for the highlighted menu. Alternatively, press the OK button. Scroll up or down to the required option.
• < button: Press and release to return to the previous menu.
• < button: Press and hold to close and exit the instrument panel menus. The OK button extinguishes and the MENU button illuminates to confirm deselection.
The displayed menu options are as follows:
• Phone: Only available when a phone is connected.
• Media.
• Driver assistance.
• Trip.
• Display. The interactive driver display is configurable. Use the Display layout menu to select a Two dial, One dial, Full map, Media, or a Driver assistance view.
• Head-up display.
• Vehicle settings.
You need to go to Driver assistance/Speed limit awareness/Traffic Sign Recognition and enable it.
Post #591269 15th Apr 2021 5:39am
Bg259
That option is not there.
Post #591273 15th Apr 2021 6:46am
Kot
It is not standard fitment for a Vogue if you had SE then you should have it.
Unless of course if it was added as an extra when first ordered? 2018 SE SDV8 4.4 Byron Blue
Post #591277 15th Apr 2021 8:20am
adara
Do you have the 2 cameras in the windshield, in front of the rear view mirror?
Post #591282 15th Apr 2021 9:29am
Martin2
Yes, it's part of the Drive Pack on the Vogue, or Drive Pro Pack which includes Adaptive Cruise etc which is standard on the VSE and above. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #591287 15th Apr 2021 10:54am
tomo141
I have this setting on mine, when i try to set the speed limit + 5mph it flashes to prompt your attention.
However, it doesn't remember the setting, therefore every journey i have to reset. Is this just the way it is`? or am i missing something? ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #591651 18th Apr 2021 6:21pm
adara
I set mine to speed + 10km/h 2 years ago and it stayed that way...
Post #591658 18th Apr 2021 7:49pm
