![]() | Home > Technical (L405) > L405 Upper wishbone bushes |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 477 ![]() ![]() ![]() |
There should be no movement in the wishbone bushes, you need to replace them by the sound of it. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
10-15mm is one hell of a lot of play. That definitely sounds like the source of your problem. Kev
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
cupples did you do the swaybar bushings yourself or have them done? I have a clunk as well and have a pair of new bushings to put on and am curious how the install went/difficulty.
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 67 ![]() ![]() ![]() |
The swaybar bushes were done by the dealer under warranty. I have it booked back in to investigate the remainder of the noises. I'm pretty fed up; surely a basic check at the dealer of the main bushes, wishbones etc should have been conducted at the time. |
ah thanks for the info.....any update? 2014 FF Autobiography 5.0 SC
not yet, going in this week |
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
I agree that the dealerships should be spotting these worn parts more regularly. Some of us haven't got the ability or knowledge to check these things ourselves. My own, admittedly second hand, L405 was checked at service by an Indie who spotted worn lower bushes and joints . These were replaced under the extended warranty scheme that I have. |
