![]() | Home > General > RR L322 3.6 TDV8 - Buying Advice and Retro Fit Tow Bar |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
3.6 vs 4.4.
GeordieGeoff Member Since: 06 Nov 2019 Location: Newcastle Posts: 6 ![]() ![]() |
Thanks for the guidance. The 3.6 although listed with FLSH had a glaring hole in the book as no service was carried out last year due to lockdown impacting the owner in some way. It also missed its MOT last year which I established once the true reg plate was confirmed. Given the missing service is the all important 10 year service with all the additional trans/diff/axle/coolant items, and that the dealer selling it now only did a basic oil service, I’ve walked away. Therefore I think I’ll press on to find a 4.4.
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
If it helps I have had my 3.6tdv8 for two years, I purchased it on 70k with full service history
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
For everyones information, whatever PF Jones website says, Westfalia towbars are no longer available for the L322 from anywhere unless you can find one 'old stock' somewhere. Ask me how I know! I have a Witter unit read to fit when the weather warms up a bit. Drives:
Thanks for the additional feedback. Very nice set up you have there.
I did the 10th Annual Service and full Transmission Service myself (Although I am lucky I work for a Ford Dealership so have access to a workshop) and I used all genuine parts and fluids. It still cost me a lot of money, but considerably less than retail
Andygriff73 Member Since: 29 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
The Westfalia is the best towbar to get if you can source one. I have just bought my first L322 which never had a towbar fitted and found a new old stock Westfalia at Chester towbars but he wanted £870 fitted with 13 pin electrics. I found a good second hand one off flea bay bought the 13 pin electrics from P F Jones for £54 fitted it myself all in with 4 brand new bolts from Duckworths it owes me £280 failing that the Steinhof detachable is not a bad looking towbar and a forum member has fitted one and looks good. I have a very high mileage 4.4 both turbos were done at 160k so I think it’s a lottery but they are beautiful cars I have had P38’s and classics in the past you can’t beat them for towing I think a good 3.6 tdv8 remapped will give you similar performance to a 4.4 but you have made the first step by joining the forum the wealth of knowledge these guy’s have is unbelievable and good luck with which ever one you choose. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 467 ![]() ![]() ![]() |
I agree with N.M Jones on this, I’ve had both and the 4.4 is in a league of its own, the 3.6 will not disappoint and I had one with 165K on it trouble free on the turbo front, but once I upgraded I never looked back, also the gearbox is a dream with the 8 speed ZF. Hope you find what you’re looking for |
Disappointing about the Westfalia no longer being available. Personally I would just look for a car with a tow bar on it. Even if it is just the main armature, then the farmers or detachable could be more easily sourced. There is nothing that can't be fixed with a hammer😜😜
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 191 ![]() ![]() ![]() |
I fitted the PCT flange bar from P F Jones with the wiring kit, not that difficult and cost about £200, seems solid enough to drag a cattle trailer all around the countryside. |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 965 ![]() ![]() ![]() |
when i had my td6 i retrofitted the whole lot..... probably took me about 6 hours.... taking my time and not working too hard, i seem to remember using a trolley jack to get the new cross brace in place as i was working with my 75 year old dad....im no spanner wizard but i do know one end of a spanner from another is you get my gist.....
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I loved the 3.6, we had the Westfalia tow bar and while It didn’t tow very often, when it did it was superb!
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Hi, I did the write up on the Steinhof bar, it’s still going strong. Happy to answer any questions if you have them, but just search for steinhof and you should find it easily enough. Cheers! FFRR 4.2SC/KTM 990SMT Current and cherished.
I agree with the above, I personally don't think that the 405 is as stable a tow car as the 322. Both of the 322's I had felt more planted than the 405 when towing. Maybe its a personal thing, or something to do with the aluminium shell, I don't know, but the 405 just felt a little less stable when pressing on with the journey on back roads.... That said they are both outstanding tow cars and neither is exactly "unstable"... |
