Home > Technical (L322) > Electronic Hand Brake |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Mine was doing that, I think it's because it only goes on when the fatty is stationary and so doesn't self clean. I just used it half a dozen times from creep speed, just pull and hold it, first couple of times it sounded like rusty brakes, then it cleared and now works fine... Pete
13th Apr 2021 8:36am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3076 |
Thanks Pete, I'll give that a go.
13th Apr 2021 11:11am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Have you tried adjusting the parking brake/emergency brake shoes manually Dave? They may be to far away from the drums. |
13th Apr 2021 1:44pm |
I've not done anything yet.
13th Apr 2021 2:13pm |
No special settings for an MOT... mine did just the same, I think the shoes pull to a preset torque which is not enough when dirt is present, clean them off by using it while in motion and it wipes the shoes... mine now works spot on first try...
13th Apr 2021 8:48pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
MOT brake test is normally just the MOT tester driving the car with a device in the passenger's footwell... |
13th Apr 2021 11:37pm |
Remember the Park brake is also an Emergency brake button too so, if you pull it up when your rolling it will do an all out emergency STOP! And spread you all over the windscreen! |
13th Apr 2021 11:39pm |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 |
To test park brake at MOT with a decelerometer the park brake is put into test mode by being stationery in neutral, hold foot brake & then four applications for on & then three applications for off with the EPB switch all with in twenty secs I think. It will then come up on dash park brake in test mode. It will then only apply park brake whilst being driven to effectively test park brake or to test on a slope. If ignition is cycled it will drop out or if you drive above 30 mph approx. They can be temperamental to get test mode established, but never known not to come out. May be worth checking park shoes / adjustment, they may have had several goes at getting the efficiency req for a pass. The info for establishing test mode is available to the MOT tester from specific info for the vehicle being tested. Apologies if I have got the sequence slightly wrong going from memory!
14th Apr 2021 4:48am |
