Home > Technical (L322) > Multiple faults 2007 TDV8, can't find the reason. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I would start with a new battery and check the alternator output... if battery voltage is not correct loads of codes keep coming up... I had loads of codes from different systems but when I replaced my alternator and battery all the codes went. |
12th Apr 2021 10:53am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Could also be the steering angle sensor, given you already have issues with the lock.... .
12th Apr 2021 11:36am |
Vadim L Member Since: 02 Apr 2021 Location: Saint Petersburg Posts: 4 |
Thank you for the answers!
12th Apr 2021 1:45pm |
Well, I have to say something about my alternator.
13th Apr 2021 6:40am |
j7wal Member Since: 13 Mar 2022 Location: London Posts: 3 |
Hey Vadim L. Did you ever find the answer to your problem?? |
13th Mar 2022 7:09pm |
Hello mate! I have sold this car last year with no heavy issues that I’ve described. But the new owner says he has the same errors. In my opinion here is the problem with the fuel system at all. Maybe it’s a good idea to check every inch from the low-pressure pump to injectors through the fuel lines and high-pressure pump. |
14th Mar 2022 5:36am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i would go into each module with your code scanner and look for faults there.
14th Mar 2022 9:31am |
Hi Vadim. And everyone else who needs help with this problem. Thanks for getting back so quickly. The reason I asked, was to actually help you and any other poor sole that "like me" Has spent a small fortune on this car trying to fix this unique problem. I followed all the forums and replaced battery, both MAF sensors, both MAP sensors, brake light switch, fuel filter. We took it to a garage last week because it got so bad it would not even start. Garage said turbo has gone but we knew it wasn't. The car was in the same spot as when we left it, it was obvious they didn’t want to get involved. I was convinced it was a single problem causing ~ LOSS OF POWER, ENGINE SYSTEM FAULT ON DASH, SUSPENSION LOWERING AND COMING UP FAULTY, HDC FAULT, TRANSMISSION FAULT, ALL TERRAIN FAULT, PARKING SENSOR FAULT ETC - ETC - ETC. It got so bad, the fault code reader was coming up with all manor of faults, it even said ALL my lights were faulty. ANYWAY, Lads and lasses, I decided to bin the fault code reader and chuck it in the back of the car and go back to basics and with a friends help, physically look and feel our way around the engine so you must first pop off the big plastic cover on top of the engine. And I am glad and pleased to say we found the cause of this problem, and you won’t believe it when I tell you. One tiny wire shorting out, causing ALL these” sort of” unrelated faults happening, because the short was just spiking the whole system. Basically, the short is located in the wiring loom for number 7 and number 8 injectors. The short is precisely on number 7 injector pipe. The location if you’re not sure is when you are facing the front of the car the right side from front to back is bank 5,6,7,8. The cause! There is a big metal cover that covers the injectors and leak off pipes. You must remove this cover, it’s a bit awkward but not hard. Locate number 7 injector pipe and the loom in directly on top, lift it and cut the mesh surrounding the loom and take a very close look ( pics before and after enclosed) My guess is the metal plate put pressure on the loom. The really strange thing is, the injector pipe does have a type of insulator around it, BUT! Only part of it, almost like a zebra crossing. So, the loom was rubbing on the uninsulated part of the pipe. I guess it is really hit and miss where the loom touches. Anyway guys, I hope this helps you. Just one thing though, I found the loom on the other bank was tight too so I stuck a bit of rubber between the big metal plate and the loom, so best to check all the injector wiring. I would just like to thank my mates brother John Ade for finding it, he is the Poirot of finding faults and believe it or not, it only took him just 10 minutes to find it, but there again, he is a genius. Oh! By the way, fault code reader has found not faults 😊 |
14th Mar 2022 5:55pm |
Naki Member Since: 04 Feb 2021 Location: Boston, South Lincolnshire Posts: 34 |
Great suggestions here. I am researching a similar issue now too on a car I just bought. I will definitely check the injector loom now. 2007 L322 TDV8 3.6 Vogue SE
20th Nov 2023 12:33am |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 133 |
I see that this is an older post, but I have many of the same faults on a friends 2009 L322 4.2 Supercharged. Would this still apply? 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
11th Feb 2024 12:25am |
