Home > Technical (L322) > EPB - Should it come on when ignition off?
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I've noticed that when I manually put the EPB on I get a red P symbol on the dash and the rear wheels are locked solid, but if I just stop and turn the ignition off there is no symbol and the car rocks on the gearbox as though the EPB isn't on. Should the EPB come on automatically when stopped or has a previous owner disabled it?
Post #590419 6th Apr 2021 9:53am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
You have to put it on but it disengages automatically.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #590421 6th Apr 2021 9:56am
Weegie
You have to apply it. It doesn't come on automatically.
Dunc beat me to it! Very Happy John
GAP iiD BT
Post #590422 6th Apr 2021 9:57am
stevepen
Cheers Guys.
I'll have to remember to engage it. As it might be one of those "use it or loose it" that seizes up if not used Smile
Post #590423 6th Apr 2021 10:06am
garyRR
Indeed it is one of those "use it or lose it".
You don't need to use it all the time but, using it once every 1-2 weeks will keep the mechanism working.
However, if it did ever seize, it's not a massive job. The motor tends to still work so, it's just a case of cleaning out the mechanism, new shoes and lubrication.
But, using it once a week will prevent it from seizing in the first place. Try and make it a specific day to help you remember e.g. Saturday when you get to Tesco. 2015 Range Rover Autobiography 4.4 SDV8
Post #590752 9th Apr 2021 10:09pm
You can set it to auto in the Car Configuration Files Thumbs Up
Post #590760 9th Apr 2021 10:59pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
There is a setting in the IID tool to enable it automatically 👍
But...I haven’t tried it as I most of the time stop on our land and really don’t need it.
Post #590761 9th Apr 2021 10:59pm
stevepen
Does this need the GAP IID tool?
Post #590784 10th Apr 2021 1:14pm
Mr Tee
Can the l405 be coded thusly too?
Post #590800 10th Apr 2021 4:55pm
Yes & Yes... The IID can do this and yes the L405 can be configured too Thumbs Up
Post #590948 11th Apr 2021 10:46pm
garyRR
Changing the subject. Can the IID tool be used to programme the central locking to unlock all when clicking the remote fob once (instead of having to press once to unlock the driver's door and a 2nd time to unlock all doors) and, to unlock all when the key is removed from the ignition/ignition off? 2015 Range Rover Autobiography 4.4 SDV8
Post #590950 11th Apr 2021 10:51pm
