Home > Maintenance & Mods (L322) > Tailgate l322 can you use an updated vogue models tailgate?? |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
The earlier tailgates seem to be far better at resisting rust than the newer ones, I'm assuming you mean a 2012 rather than a 2021 model as that would be completely different (L405 models have different tailgates). Form what others have posted on here you need to look for tailgates manufactured whilst BMW owned Land Rover as the steel/rust protection appears to be the best of the bunch 2011 TDV8 Vogue SE |
9th Apr 2021 6:34am |
Merrimoo Member Since: 28 Mar 2021 Location: Edinburgh Posts: 8 |
Hi, thank you for your reply and I will have a wee look. |
9th Apr 2021 10:05am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7833 |
Yes, as time went on, more and more recycled steel was used. Trouble now is, the earlier better ones are now not always better.... as they are old.
9th Apr 2021 10:19am |
Hi, thank you I will keep looking. I could get a brand new one but very expensive a bit over 2k. However, that was for the upper and lower. |
9th Apr 2021 10:38am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Everyone says they are interchangeable but they are not 100% I got a 2002 rust free example for my 2007 - it was missing one of the heated rear screen pickups and it was missing a hole in the top for the gromet of the reverse camera wires. Luckily there was another larger hole I found a geomet that fit ant used that and the heated screen seems to work so maybe it was the aerial or something. Current stable:
10th Apr 2021 8:12pm |
Thank you appreciate your reply, I”ll just keep looking. |
11th Apr 2021 8:57pm |
