![]() | Home > In Car Electronics (L322) > Digital TV upgrade (again!) |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
What tuner die you bought? Thanks! |
Travaskas Member Since: 22 Apr 2017 Location: Dorset Posts: 3 ![]() ![]() |
Hi there,
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
You need to make sure the handbrake is on and not in gear (although neutral seems to work). You should still get the sound, though, when running with a warning on the screen. |
Hi,
I do understand - there may be a problem with the handbrake sensor by the sounds of things. I would have thought you can test that by making sure the handbrake light comes on when you apply. Goodness knows otherwise... |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
try the 753 hack but i think you may have to do this every time you turn the engine off |
Evo290 Member Since: 22 Oct 2020 Location: somerset Posts: 6 ![]() ![]() ![]() |
Did you get your tv module working in the end |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 936 ![]() ![]() |
Dont expect a reply it's a x3 year old post and he never posted again after |
That’s the trouble I think everything I look at on here I’m too late 😂 |
