![]() | Home > Maintenance & Mods (L322) > TDV8 ERG Valves |
Experience shows the TDV8 EGR valves to be much longer lived than those on the TDV6 so there's probably not a lot to be gained from blanking them off. I'm not even sure it's possible since the TDV8 commenced life right about the time when the TDV6 was modified such that blanking off caused engine errors.
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 ![]() ![]() ![]() |
If you have a DPF do not blank off the EGR valve.... Not sure which model you have.
L322 Pilot Member Since: 07 Apr 2011 Location: Solihull Posts: 13 ![]() |
I have a 2002 L322 with the M62 V8 petrol engine and the check engine light came on recently.
Suggest you download RAVE from here - http://landroverresource.com/
