![]() | Home > Maintenance & Mods (L322) > Wiper blade clip? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Buy HQ blades off Ebay. Remove all the |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Thanks, I'll have a look at that. Does that do away with the plastic sliding clip completely then?
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Here is the item no on ebay for the ones I bought
Jmagg73 Member Since: 16 Jan 2021 Location: Illinois Posts: 33 ![]() ![]() ![]() |
I got some recently off Atlantic British |
Full kit
That's great, thanks, and thanks for the other suggestions too ![]() |
MarcoPolo Member Since: 07 Dec 2018 Location: Preston Posts: 19 ![]() ![]() ![]() |
Just seen this thread so my input may be too late. If I've correctly understood which clips you're referring too, I recently purchased these when replacing the wiper blades on my 2003 L322. The part number is DKW100020. Both aftermarket and genuine versions are available from all the on-line suppliers I usually use. They were quite inexpensive, even the genuine ones, as you'll see if you search the part number. My apologies if this reply is too late |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
bogdan xtr Member Since: 06 Nov 2020 Location: bucharest Posts: 6 ![]() ![]() ![]() |
Also a match from bmw e 39 |
