![]() | Home > Technical (L405) > 5L Supercharged, Oil In Coolant |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Page 2314 of the Workshop Manual...
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Thanks Pete.
The rubber is not likely to leak, it usually leaks where the rubber meets the metal fittings... no relevance to your original issue though.. Pete
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
As coolant is cheap, perhaps worth to empty, flush and refill the system fully. Then monitor it from there. I’d be generous with flushing it out |
So just an update, I’ve replaced the transmission oil cooler and tested the old oil cooler for leaks but none apparent cold.
