![]() | Home > Technical (L322) > 3.6 TDV8 Losing Coolant |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Loads of places it could be, one common one is the expansion bottle itself, a small split will leak when driving and the system is under pressure... worth taking it for a run, get it nice and hot, stop, open the bonnet and listen with the engine on, if you can't hear anything turn the engine off and you may hear where it is escaping... |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Good news is that it’s not the head gasket. To be honest I think it’s rare. On a car of this age it is much more likely that one or more of the 1,001 coolant hoses, pipes or connectors need replacing. And then you find that once you’ve done one you just move it to the next weakest spot etc. So in my opinion when a car gets to that age in its life just change the lot. It’s cheap, looks better and keeps the leaks away. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Sorry, I'd forgotten to mention I have replaced the expansion tank as a previous preventative measure. |
This is my assumption and, the hole in the hose is only coming when the coolant is hot and under pressure. I may have to put into a garage to get them to put it on the ramps and find it. |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
Look very carefully in the 'V' with a torch. You may well see dried coolant. If so, there is a good chance it is your plastic thermostat housing that has split. It will leak under pressure into the 'V' where the heat evaporates it leaving your orange stain! My betting is that this is where your problem lies. |
Is there a best position to view it from? |
Take off the plastic cover and point the light down towards the front/middle of the 'V'...easiest bit to get to luckily! It won't be too hard to see! |
Thanks.
Sounds like a good plan! If it isn't the actual thermostat housing it may equally be one of the plastic pipes that go between the engine and the thermostat..same difference repair-wise! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
EGR cooler? |
From the limited amount you can see in the engine bay without moving things, there is no sign of any pink inside the V of the engine.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
sorry to thread hijack, what are the plastic housings like to replace?
There's a thread on this site of a top end strip down to replace the EGRs. Replacing the thermostat housing is the same job with the final few steps removed.
ah ok, not too sad then, thanks for replying 2009 (2010 MY) 5.0 Supercharged Autobiography
