Home > Technical (L322) > Check real lights - Dash Error Message
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I had to replace the rear cluster on the drivers side as it was cracked beyond all repair. I have swapped both out for new ones not genuine RR so the ebay jobbie. Purist dont shout 😂
I have the check rear lights come up on the dash. They are fine and working well. The message does go but annoying on start up. Is there a way to clear this message. I get this with check n7mber plate light which i swapped out for brighter LED. Again works just annoying to have these messages so would like to remove them if possible. Current Cars
2006 Range Rover Vogue 4.2 V8 Supercharged Petrol
1996 Williams Clio 2
Previous cars
Bentley GT Continental
Porsche Cayenne 4.5s
4.2 V8 Supercharged Range Rover
Porsche Boxster 3.2s
Ford Kuga
Nissan 350z
BMW 316
Porsche Boxster 2.5s
Golf 2.8 VR6 Highline
Renault Clio 16v
Vauxhall Nova GTE
Post #589976 2nd Apr 2021 11:43am
the GAP iidtool can switch off hot and cold bulb monitoring ..try a battery reset first. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #589983 2nd Apr 2021 12:46pm
Ashmyster79
Hi stan.
Good tip will try a battery off and see if that resets it. Saying that though battery had been off for the work i was having done and previous error is still there with the number plate light. More annoying than a real issue.
Cheers buddie. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #589985 2nd Apr 2021 1:02pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I put a set of what sounds like similar items on my 2005 VSE last year, and whilst the looks from the outside were of a good quality item, I quickly discovered two problems.
The first being that the tail lights flickered very slightly and occasionally went out and back on again within a couple of seconds causing the bulb error message to appear. This was fixed by taking the bulb holder out and gently bending the metal contacts behind each bulb to apply a little more pressure.
The second issue was that I found the rear fog lights seemed to be on all the time due to the metal contacts for the tail light and fog light being installed in the wrong positions in the bulb holder causing the wrong elements to be illuminated in the lower tail light bulb. This didn’t thrown any error messages but it had started to melt the bulb holder slightly! 😬 After some minor surgery I managed to switch them to the correct position.
If you still have your old tail light units it may be worth comparing the bulb holders, or even swapping the bulb holders back to the originals. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #590059 3rd Apr 2021 1:14am
Ashmyster79
100%. Whilst I haven’t seen what lights are on when I am driving I do think perhaps I will swap the internal units over and see if that works. The bulbs were different in the new ones sent red opposed to the silvery blue ones I had on the old lights. Also it was the lense that was cracked on one side. I didn’t realise you could buy replacement lenses. Cheaper too!!!
Might just buy them put them back in the old units and send new ones back. Un-used of course 😂
Let me try internals swap over back to originals.
Good tip. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #590072 3rd Apr 2021 7:56am
RichTD6
Thumbs Up 2012 Westminster TDV8 4.4 Indus Silver
Post #590086 3rd Apr 2021 9:51am
