Home > Maintenance & Mods (L322) > Rear tailgate issue / loose bolts
jcoops
United Kingdom 2009 Range Rover Vogue SE TDV8 Bonatti Grey
Hi guys,
Got a small issue with the tailgate strut where is connects to the chassis. Annoyingly if I turn the nut the bolt simply rotates and does not tighten, it is hard to describe but I'm guessing that something has broken of inside of the frame. It is currently really loose and feels like it may pop out at any time. It looks like I may need to remove the black fascia to get to the internal side of the bolt. See photographs below.
1st image shows the issue, 2nd image shows what it should be.
Post #590079 3rd Apr 2021 8:06am
kevinp
I had my external D pillar covers off to paint them and I don't think there were any holes that you will be able to reach the back of the stud. I think you might have to remove the inside trim mate. Kev.
Post #590085 3rd Apr 2021 8:51am
jcoops
Ok will have another look this afternoon.
Thanks
Post #590101 3rd Apr 2021 10:42am
Funkton
Australia 2009 Range Rover Autobiography TDV8 Santorini Black
I had this same issue 12 months ago, I disconnected the strut, pulled the bolt tight using fingers and used the friction to tighten it internally then give it a good tighten with a wrench.
Hope you got it sorted.
Post #599753 6th Jul 2021 5:52am
