Home > In Car Electronics (L405) > Start/Stop button kill switch fitment
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
2016 vogue se sdv8 euro 6
Hi all
Looking at fitting a hidden kill switch on the start stop button as extra security
Would anyone know which wire I need to connect the switch too ?
Black
Purple
Blue/white
Yellow
Green/White
Canโ€™t seem to find any L405 wiring diagrams that relate to the ignition switch
Thanks in advance Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #590013 2nd Apr 2021 4:29pm
there are wiring diagrams for stop/start in the WM which is in the wiki.. ... - .- -.
Post #590014 2nd Apr 2021 4:38pm
aljo
Hi Stan
I have the L405 wm already downloaded but canโ€™t seem to find any specific diagram for the start / stop wiring as shown
They wire I need obviously wonโ€™t go straight to the starter motor but through a module
It may also be that Iโ€™m having blonde moments today ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ which could explain why Iโ€™m having trouble finding anything that makes sense Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #590016 2nd Apr 2021 4:51pm
its in the wiring diagram section under starting system... ... - .- -.
Post #590019 2nd Apr 2021 4:59pm
aljo
Would I be right in thinking itโ€™s the blue/white wire ?
Post #590021 2nd Apr 2021 5:30pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The stop/start switch is shown in the "ANTI-THEFT SYSTEM Passive start" section of the wiring diagram. You could use the green/white (stop/start ground), this may generate fault codes due to the electronics detecting a break in the wiring.
The blue/white and black wires are for illumination supply and earth respectively. (Earlier models with the 4-wire switch used the green/white wire for illumination earth)
Post #590070 3rd Apr 2021 6:37am
aljo
Cheers Fifth Horseman ๐Ÿ‘๐Ÿ‘
Many thanks for that info Bow down Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #590090 3rd Apr 2021 9:30am
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Did you get anywhere with this? Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #596442 5th Jun 2021 12:11am
