Home > In Car Electronics (L405) > Sat Nav thinks I am somewhere else
supershuttle
I've had a search and didn't find anything. My SatNav thinks I am somewhere else I know where I am, but when I switch it on the SatNav shows me as being miles away. Is there something I can set or reset? I've been using Waze and its great but for simple "get me home" stuff the inbuilt SatNav is more convenient - well it was. Geoff
Post #589747 31st Mar 2021 6:53pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think you will find that the aerial on the roof will be the problem? I had the same with my golf, I got a unit on eBay that just plugged into the back of the radio and sits in the dash? you may be able to use the same thing for your problem cheap fix?
Post #589782 31st Mar 2021 10:21pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Either your GPS receiver can’t get a lock for a reason to be determined. Or you are in an area where there might be an active operation in progress. I used to have that a lot in a certain area where I was staying in a hotel. Was a pain in the backside to order an Uber as it would never show me on the map where I was.
Post #589784 31st Mar 2021 10:25pm
supershuttle
Had a play this morning, the GPS box has a red diagonal line through it don’t know why, but I suspect that’s the root of the problem Geoff
Post #589812 1st Apr 2021 8:43am
Chalky
What year is your car? All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #589846 1st Apr 2021 11:24am
supershuttle
2013 Geoff
Post #589885 1st Apr 2021 3:58pm
Chalky
Ah, ok, I was just asking in case yours was a facelift 2018+ car because I had issues with software(including your satnav problems), which only resolved themselves when they fitted a new unit. All LR cars from 1984
Post #589887 1st Apr 2021 4:03pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
https://www.fullfatrr.com/forum/topic58813.html
3rd post down. Known problem which requires a software update to rectify.
Post #589999 2nd Apr 2021 3:11pm
supershuttle
Differing views on this, what's under the roof arial cover thingy, is it just GPS or is there an antenna for something else as well? I think I might take it to bits and have a look but if someone's already done it would be helpfu to know in advance what I might findl. I have ordered another GPS antenna from eBay to try, it was only a tenner so can go in junk box if it doesn't work. Another query is where does the GPS box/amp live in the back or is there not one. My car is as described to the left 2013 L405 Autobiography TDV8 Geoff
Post #590020 2nd Apr 2021 5:02pm
Bora20
My 2013 acted just like yours. GPS symbol with a line brought it. Thought I was in Washington DC sometimes, but I love on the west coast of Canada. 100% a software update.
Post #590121 3rd Apr 2021 3:47pm
