![]() | Home > Technical (L322) > Dash Illumination |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Am I missing something. They look on to me |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
They do look that on photo but maybe they are just dim. I thought the actual temp set had a small indicator as well which obviously moves when temp altered. I maybe need to wait till it's very dark and see😎🌘 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
From memory, there is no separate illumination to show what the temp is set to. Just the ridge on the actual knob that signifies what you are set to. 2011 TDV8 Vogue SE |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Mine after dark, does it help?
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Indeed the same on my 2010+ model |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Lit on mine too...
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Thanks for the pics guys, it seems mine is the same so panic over. Think I must have been dreaming on what I saw😂 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
The fan speed illuminates to show what speed setting its at, maybe you confused it with that.
Cheers Rob, checked this and your right, confused.com! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
