Home > Maintenance & Mods (L405) > Installing Fixed Side Steps
Rob99
I've been looking through the instructions to fit my side steps and it shows that the aluminium underbody shield below the engine/gearbox area needs to be removed.
Having stuck my head under the car it just looks like only 2 or 3 of the underbody shield bolts on each side are connected to the side sill panels which have to be removed so I'm wondering if the whole shield has to be removed or just the affected bolts loosened.
Cheers
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #589267 27th Mar 2021 7:04pm
Rob99
Anyone? 2021 D350 Fifty Edition - Carpathian Grey
Post #589531 30th Mar 2021 11:44am
my eldest fitted mine so i dont know what it looks like underneath but he did have to cut a small piece of plastic which was obscuring the mounting location..
found this,
https://www.sidesteps.co.uk/wp-content/upl...ctions.pdf
and theres also a few fitting videos if you google. ... - .- -.
Post #589537 30th Mar 2021 12:47pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
You certainly don’t need to remove the undershield to take them off, but that isn’t helping - unbolting it might make things easier getting the fibre covers back on, and I don’t think it looks like a lot more hassle to do so.
Post #589538 30th Mar 2021 1:31pm
Andy B
My Model Year is slightly different to yours and the under tray parts are a little bit different (Duckworths confirmed this), however having removed the steps from mine I noted cut outs to enable the step brackets to be attached to the car. If similar to mine, you will need to also loosen the under trays to get to the bolt holes
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #589542 30th Mar 2021 1:43pm
Rob99
Thanks all.
Seems like the sensible approach will be to remove the undertray as it certainly looks like it will be much easier to re-fit the fibre panels.
Apart from that, the instructions don't look that difficult so will tackle this over the long weekend as the weather forecast looks good. 2021 D350 Fifty Edition - Carpathian Grey
Post #589548 30th Mar 2021 3:06pm
