Home > In Car Electronics (L322) > Latest NaviPlus install on a L322 2010+ |
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 67 |
All the best with the install - it's relatively straight forward, it just burns a lot of time, and there's a little bit of "dot puckering" while trying to fold the screen circuits back together without snapping the ribbon cable and somehow routing the touch input & LVDS cables back out without fouling anything...
25th Mar 2021 5:31pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Awesome. Thanks. And yes there is a lot of cable and several boxes to hide. And then there is the antennas as well. At least I seem to have read a technique such that you don’t have to take the fuse box out.
25th Mar 2021 6:18pm |
Oh, yes you definitely don't need to remove the fuse panel - I certainly didn't.
25th Mar 2021 9:04pm |
If you don’t mind that would be awesome. Part of me was wondering whether to run it to like the new MagSafe connector for easy wireless charging I’ve got currently a wire running out of the arm rest cubby, but the standard usb socket is not that powerful so I use a longer cable from the rear cigarette lighter with a rapid charger. |
25th Mar 2021 9:19pm |
OK, here's where I have the USB socket emerge from the dash in the passenger footwell:
26th Mar 2021 9:48am |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Video would be great. And if by chance yours is a face-lift 2010 model would be nice to see top dash panel removal in close up ie clips etc. Hope all goes well I really want it just can't afford at the mo. I brought a Bovee as a sort of stop gap make do but it didn't work. |
26th Mar 2021 9:53am |
Once the end caps have been removed, the dash top was pretty straight forward to remove. The only thing I remember burning far too much time on was releasing the centre vent - it has those metal spring clip things holding it in place along the edge nearest you.
26th Mar 2021 10:07am |
Awesome...That last comment will safe me a lot of time I think
26th Mar 2021 10:48am |
Well I'm burning lots of time getting those glove boxes out
27th Mar 2021 12:53pm |
Finally found it, to get the glovebox to fully open in the service position you need to move the hinge that is closest to the centre console outwards. So for Uk cars to the passenger door.
27th Mar 2021 1:02pm |
But I can’t figure out the “easy” part which is taking this bit off It seems to be stuck on those highlighted points way more that just those pop clips can do. I’m wondering whether these later cars are different somehow. I need to apply way to much force for my liking such that I don’t want to proceed in fear of snapping it. I looked at the wiki workshop manual but that is as good as useless for this.
27th Mar 2021 1:44pm |
Ok got it. It’s flipping scary though, I really didn’t like pulling that hard on plastic. I tried to get more leverage from inside with my large trim tool.
27th Mar 2021 1:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
have you read this, might help your instal,
27th Mar 2021 2:03pm |
Thanks.
27th Mar 2021 2:42pm |
