![]() | Home > Technical (L322) > M62 4.4 Coolant leak from cap |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 595 ![]() ![]() ![]() |
I drove 200 km yesterday, no leak from the cap. Checked coolant level this morning and it is still the same! Also there's no more leak from the quick coupling. Yesterday morning it was literally dripping. There is still some moisture on the under tray and coupl8ng which clearly shows there indeed was a coolant leak at some point. How can this just come and go??
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
The cooling system is notorious for air locks, it could be you had one that has now worked it's way out, whilst there it increases the pressure in the system and it will leak at the cap... When it's gone the leak goes... Worth changing the leaking hose and then bleed the system through well, check all hoses are warm when it's at running temp... some will be cooler than others but none should be cold...
Thank you gentlemen for the valuable advice. It seems as if the leakage of the water pump was acting as a relief and now the weakest spot has been exposed in that hose's quick coupling. I'm wondering if air could be drawn into the system from a hairline crack or a failing coupling. Then cause an air lock and a leak from the cap.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
And as I’m sure you know. Once you’ve fixed the next weakest point, the following one will rear it’s ugly head. My attitude is that if one goes then it won’t be long before others go. Hoses are cheap, my time or labour of others isn’t. In my opinion it’s best to change the lot and then have another 10-15 years of trouble free cooling system. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1548 ![]() ![]() |
![]() I've only got a T4, a Faultmate MSV, and a GAP IID Tool (and access to Autologic)! ![]() I'm not sure where but I'll have a look. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
IID should have it somewhere... |
Judging from what I've faced so far I should have replaced all hoses from the get-go. Most all faults (so far) have been rubber gaskets, o-rings and hoses. At the moment many of them have been renewed. Some time next year I should be tackling the timing chains and Vanos. I have no problems at the moment, other than a bit of oil sweating through the upper timing chain cover on the left hand side. So small that it won't make any difference in the leven between oil changes. But chain guides are inevitably due to fail at some point. I will change the entire set of hoses while at it. I'm slowly gathering the parts and talking my indy into ![]() |
The bottom part of your rad has a takeoff for the transmission cooler, there is a manifold and separate thermostat down there, the bottoms of the rad sludge up as the bottom hose is high up on the side of the rad so the water in the bottom doesn't move much...
Here you go...
Hey Pete, I purchased this car specifically because it had a nearly brand new gear box. First things I replaced were the radiator, the oil cooler + its base / fitting and the T-shaped joints as they seemed getting whitish (assume that is the gearbox thermostat assembly) I'm definitely keeping it until an L405 begins to make sense with taxation and all here...That is probably in the next 5 years. A quick question: I drove about 100Km today again with no coolant leak observed. Upon switching off the engine, I noticed that the expansion tank cap was hissing slightly then soon stopped. No coolant emerged. Is this part of its normal operation? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 499 ![]() ![]() |
I'll have to double check what's on mine, it's one of the very first L322's (2002). I had 'fun and games' getting the correct cap when I worked on the cooling after a hose blew, so I replaced the majority of the hoses as a precaution. No issues since. I was sure that the later cars run higher pressures, but happy to be corrected. Ron - I'm sure you're reading MicroCat correctlt, let me just re-assure myself first! I'm going outside now to look ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Yep, I got it the wrong way around... The earlier cars have the 200 cap - mine has! Doh |
I never noticed mine doing that, mind you mine was changed to a lower temp so lower pressure as well... Do the stat mod, or swap, and then see if it does it... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 770 ![]() ![]() ![]() |
can you explain what you mean by "closed loop" please RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
