![]() | Home > Maintenance & Mods (L322) > Issues with turbocharger actuators |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I would be inclined to get another quote from somewhere else to help put it into perspective. They are quite expensive there... 2010 4.4 TDV8 Vogue SE |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
What faults are you getting?
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
£850 to free up stuck actuators is taking the |
jcoops Member Since: 27 Jul 2019 Location: Farnborough Posts: 23 ![]() ![]() ![]() |
The suspension works fine, occasionally in rare circumstances it has come up with a fault but taking your foot of the brake and re attempting a lower / raise and it works fine. I do not plan to do any work to the compressor. Having read yours and the other responses I will contact another garage to ask if they can help. |
Thanks for your response, I'm going to go to another indy to see if I can get a better quote and not feel like I am being fleeced. |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
A new AMK compressor is about £450 so I would like to know what the other £400 is for. A Hitachi compressor is about £150 again what's the extra £400 for?
I've contacted another indie closer to me and will get alternative quotes.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Get a good local mechanic to give you a price.
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
I had a stuck l/h actuator linkage on my TDV8 when I bought it a couple of months ago... it had been stood for a while before I got it. I went to my local garage and we put it on the ramp. I sat in the car and Jon who owns the garage got his torch out and used a long rod and a can of wd40 to free up the actuator whist I cycled the ignition a few times (the actuators go through a test cycle each time you turn the ignition on and then do the same after you switch it off). Took 10 mins and he did not charge me....
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
also keep your foot off the brakes when raising or lowering the car!! |
Update: took it to a local indie and he solved the issue by loosening the stuck actuator. Cost £200 all in!
nice |
