Home > Technical (L322) > Smoke from back of engine not the usual suspects
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Recently had the oil cooler and the o rings replaced in the oil return pipe and I’m still getting smoke coming out of the engine, I took the engine cover off and removed the filter box the back of the engine is bone dry, I park on a sloped drive with the Bonet higher than the back of the car it’s driving me nuts, could it be the dpf or something else, I also had the gearbox filter and oils changed not sure if this has an impact I took a video of the smoke coming out but no idea how to upload it 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #588936 25th Mar 2021 6:29pm
first thought would the fbh..
put your video on youtube and stick the link here.. ... - .- -.
Post #588938 25th Mar 2021 6:47pm
Furnitureman
Hi Stan not FBH that works no issues this is a burnt oil smell 2012 Range Rover Westminster 4.4 TDV8
Post #588942 25th Mar 2021 7:02pm
Furnitureman
Hope this works 2012 Range Rover Westminster 4.4 TDV8
Post #588944 25th Mar 2021 7:07pm
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
carpet that crumbles
air conditioning filter box
or oil leak from the oil cooler I had the same problem
Post #588986 25th Mar 2021 10:57pm
Furnitureman
oil cooler has been fixed and the back of the engine is dry no oil, i think its coming from further back just no idea where to look now 2012 Range Rover Westminster 4.4 TDV8
Post #588999 26th Mar 2021 6:15am
Corsica
It's protection deteriorates and falls on the exhaust which causes smoke
https://www.ebay.fr/itm/Range-Rover-Vogue-...4673939571
Post #589001 26th Mar 2021 7:15am
Furnitureman
I can look at that but i think it’s too much smoke the insulation looks ok but I’ll check it 2012 Range Rover Westminster 4.4 TDV8
Post #589002 26th Mar 2021 7:55am
DrRob
Smell? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589003 26th Mar 2021 7:57am
Furnitureman
Burnt oil 2012 Range Rover Westminster 4.4 TDV8
Post #589006 26th Mar 2021 8:53am
DrRob
Whip off pollen box and look. Could be old oil or the O rings are Censored  Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589022 26th Mar 2021 10:38am
Furnitureman
took the box off and climbed on top of the engine all 18stone of me Rolling with laughter much to the amusement of the neighbours to get a good look down the back, bone dry the garage had cleaned it down and no leaks anywhere the oil cooler is clean as is the o ring pipe 2012 Range Rover Westminster 4.4 TDV8
Post #589035 26th Mar 2021 12:49pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
What about from underneath, any oil drips showing around bellhousing etc. You should be able to put the vehicle into extended height, open one of the doors to stop it dropping down and slide underneath with a torch and have a good look round, you might need to remove the under tray but that’s a straight forward job 2011 TDV8 Vogue SE
Post #589046 26th Mar 2021 2:00pm
Furnitureman
nope all dry it was covered in oil when i got it but after the oil cooler etc was changed and they cleaned it down its been dry, they have told me to take it for a blast and bring it in and they will put it on the ramp whilst im there hopefully we will work out the issue 2012 Range Rover Westminster 4.4 TDV8
Post #589050 26th Mar 2021 2:29pm
Furnitureman
just had it on the ramp at the garage the back of the engine is bone dry no oil to be seen, he is just as stumped as me 2012 Range Rover Westminster 4.4 TDV8
Post #589057 26th Mar 2021 3:51pm
