Home > Technical (L322) > I was told to steer away from a 4.4 TDV8 and get a 3.6 TDV8
Page 1 of 4 1234>
Johannes
Estonia
Hi!
Í am looking to buy an L322 and was looking at the 2012 4.4 TDV8´s as I thought these would be the most trouble free versions and then I asked a local Land Rover mechanic for his suggestions when buying a used L322 and he told me to steer way clear of the 4.4 TDV8 engine because according to him many of the 4.4 TDV8s suffer from broken cranks which will amount to huge engine repair bills.
He suggested I get the 3.6 instead as this engine does not have that issue.
Has anyone experienced such an issue with their 4.4 TDV8?
I am really tempted to get the 4.4 because of more power, better fuel economy but after hearing of such a major issue with these engines ím having second thoughts...
The cars that fit into my budget have all done around 100 000 miles.
Is the 3.6 more reliable than the 4.4?
Thanks! Johannes
Post #588661 24th Mar 2021 7:30am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Nonsense and old wife tales. Just get what you want and find yourself another mechanic Wink
Post #588663 24th Mar 2021 7:40am
DrRob
Use a different mechanic as he's talking crap.
the 3litre V6 has the crank made of cheese not the 4.4 V8 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588667 24th Mar 2021 8:01am
Fox889
I don't wish to disrespect your 'Land Rover' mechanic....but.......codswallop! Is he a 'mechanic' who works on Land Rovers or is he a trained 'Land Rover' mechanic....there's a subtle difference.
If he said "stay clear of Land Rover 3.0 V6's because they snap cranks" then I would agree, that has been noted as a weak spot on the 3.0 V6. As far as I've read on this forum in 18 months of ownership of a 4.4 TDV8 I've never ever read of crank problems.
The only noteworthy problems found on a 4.4 TDV8 are oil cooler seals/gaskets that tend to go AWOL after a while, the secondary turbo is a 'sequential' turbo & if not used, can sometimes, emit smoke under load & high revs.
Apart from that, the 4.4 TDV8's are superb machines, and in my ignorant biased opinion, better than the 3.6 TDV8....but that's purely my opinion.
As a footnote, I would perhaps suggest seeking a more knowledgeable 'Land Rover' mechanic for any future work on any purchase? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #588669 24th Mar 2021 8:05am
Fox889
Dr Robs first line says it all & exceeds all my waffle! Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #588671 24th Mar 2021 8:06am
Johannes
Estonia
Thanks for you input! I shall ignore the “advice” given by that mechanic and will continue searching for the right 4.4 TDV8 RR for myself Smile
By the way, Is the oil cooler seals issue an easy fix or a more complex job to fix?
Thanks!
Post #588672 24th Mar 2021 8:08am
DrRob
See the Wiki for a DIY guide and loads of other support
https://www.fullfatrr.com/wiki/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588674 24th Mar 2021 8:11am
Fox889
Split opinion on the oil cooler leak on here, some replace just the seals/gaskets & some [me] changed the whole cooler because the time allocated for the job is around 4.5hrs. It's do'able if you're handy with the spanners [which I'm not] so my thought was, if it's all apart change the whole cooler & forget about it. Others will say just change the seals & gaskets....your choice. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #588677 24th Mar 2021 8:13am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
not heard of cranks failing on the FF Shocked
RRS for sure and i think that was on the 3.6 not sure though 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #588678 24th Mar 2021 8:14am
Jayk69
as for Oil cooler i am with Fox889 for the cost of the new cooler and the time and effort i was going to (I did it myself) to strip down it was a no brainer. the whole job took me and my 11 year old apprentice 5hrs. with plenty of tea as it was freezing bloody cold Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #588681 24th Mar 2021 8:20am
TJH1985
Even the 3.0 crank issue is super rare in a FFRR - it’s a Range Rover, your taking your chances either way Laughing Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #588683 24th Mar 2021 8:32am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Your "mechanic" wouldn't happen to have a 3.6 TDV8 for sale that he wants to get rid of would he?
As others have said only the 3.0 TDV6 Crank has had issues, not all but some.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #588686 24th Mar 2021 8:38am
Johannes
Estonia
No he did not offer a 3.6 for sale Very Happy
Thanks for all your input!
The 4.4 TDV8 is back on my agenda. Thumbs Up
Johannes
Post #588708 24th Mar 2021 1:15pm
garyRR
Re: I was told to steer away from a 4.4 TDV8 and get a 3.6 T
Johannes wrote:
Hi!
Thanks! Johannes
Rubbish. Mmm.... Yes and no.
The new 3 litre diesel is the engine which is known to suffer from crank failure and features in the L494 Sport and L405 FF. However, I've tried researching this before and there are no statistics available on crank failure rate. You need to bear in mind that more than 90% of diesels sold by Land Rover were the 3 litre and not the 4.4L and therefore, the incidence of people reporting problems on forums and In chat is also going to be 10x higher than for the 4.4L. I've driven both and in my opinion, the 3 litre is the better car. It's plenty powerful enough, quiet and economical. The 3 litre is a fantastic engine - my dad has it in his XF. The 4.4 adds a lot of weight to the front of the Range Rovers, which noticeably impacts the handling (as well as your wallet) and for those reasons, on the newer Range Rovers, I feel the 3 litre is the better option.
So anyway, back to the L322 - The diesel choices are a 3.6 Ford V8 up to 2009 or a 4.4 Ford V8 or the petrol choices were a 4.2 Jaguar V8 or a 5.0 Jaguar V8 (the latter of each feature on the current models). Both diesels have their share of problems, both in a cared for state will do quarter of a million miles. BUT, the engine bay is crammed full enough as it is with the 3.6L, I dread to think how time intensive and difficult repair jobs are on the 4.4L and, I feel this would also make repairs more expensive as you're realistically looking at putting it into a garage for most jobs, instead of being able to do these on the driveway.
However, the 4.4L is a more refined beast and the 8 speed box is what would clinch it for me so, although I have a 3.6, the refinement of the 4.4 would win hands down. Just bear in mind it may not be too frugle compared to the 3.6 around town and, driveway repairs may be difficult.
Post #589314 28th Mar 2021 2:20am
Johannes
Estonia
Thanks for that insight! I am currently also eyeing the L405s and especially the 3 liter diesel. I´m wondering if the crank issue on the 3 liter diesel is something that can be avoided with a preventative fix in the garage?
To my surprise the second hand L405s with the TDV6 and the SDV8 are not that far apart in terms of price. So maybe if I want to avoid an expensive engine repair in the future I should set my sight on an L405 SDV8 perhaps?
Cheers,
Johannes
Post #589316 28th Mar 2021 4:17am
Page 1 of 4 1234>
