Home > In Car Electronics (L322) > Temperature alert, system shutting down!
LowB
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I got this error on the touchscreen after a few seconds of the ignition being turned on then the whole entertainment system would shutdown. Just in case anyone else is faced with the same problem I thought I would post my findings and solution.
Not surprisingly I traced the problem to the TV module, with it being the top unit in the stack in the rear quarter panel it’s the first one to suffer water ingress. LR very thoughtfully put a big hole for the fan in the top of it which makes it nice and easy for the water to get inside. After copious amounts of contact cleaner and a toothbrush I managed to remove all the corrosion and voila! No more temperature alerts🙂 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
1998 Saab 900 turbo convertible in Lime Gold with black leather
Post #588493 22nd Mar 2021 11:52pm
Yep, a well known fatty leak spot, have you done something to shed any more water that pours in..? Pete
Post #588565 23rd Mar 2021 5:00pm
LowB
Not so far, it's wasn't immediately apparent where the water gets in. It was certainly damp in there when i picked the car up but I've been checking it ever since and it's remained bone dry in there so far. Any clues as to where it gets in? 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
Post #588570 23rd Mar 2021 5:44pm
Several culprits including the window, JLR did a shield which was basically a sheet of plastic to shed water away from the top of all the electrics. Wrapping them in a plastic bag should help, I doubt it's a one off... It usually only leaks when the car is parked in a particular orientation to the rain... Pete
Post #588578 23rd Mar 2021 6:27pm
