Home > Maintenance & Mods (L322) > 2011 Range Rover 4.4 tdv8 oil consumption, new turbos etc...
Edward
My 2011 Range Rover Vogue 4.4 tdv8 ownership experience started last year with rather heavy oil consumption, but rarely any smoke. Certainly none at all when accelerating to engage the 2nd turbo.
After a few thousand miles of ownership trying to convince myself that perhaps I hadn’t quite filled it up previously and ‘let’s just add 1 more litre and see how it goes’ etc, I saw a general dampness of oil over the alternator, and a drip coming off of the bottom of the bell housing. Obviously these little drips didn’t account for the amount of oil it was using, but it did lead me to the decision to drop the engine out to have a proper look at it all. I think this car is one I’ll keep and of course you never really know a car until you’ve got involved with it’s workings...
I run and work at my small family garage and have a redundant building which I could use to do the job over a period of time.
So it all began, front off, wheel arches undertrays off, exhaust off, shields off, prop off etc.
Lowered the front subframe complete with engine and gearbox down all together on the pallet truck!
Other observations so far on the car, the centre prop bearing is completely worn out also the car has had a previous repair to an air suspension pipe which is leaking - this would explain why the car had had 2 new compressors in quick succession recently in the hands of the previous owner.
Now looking at the engine, the oil consumption proved to be coming from the NS Turbo with oil being in the intake pipe where it recycles its air when it’s not engaged and also a fair load in the inter cooler... so engine hoisted, the cv joints are totally seized in to the hubs (even using a 12 tonne hydraulic press), so I removed the whole hub assembly complete with driveshafts. Removed the diff and got the turbos off - decided to do both whilst I’m at it.
The inside of the exhaust manifolds were coated in wet oil so the engine has actually been smoking a lot but the dpf has been working overtime to stop it coming out the back I assume! This oil is mirrored when you look in the inlet manifold from where it’s been inhaling it over a period of time.
Next job was to slide hammer the core plugs out of the sump, drill, tap etc and fit the much discussed double turbo drain mod. Clean it all up, fit some recon turbos and re-assemble the plumbing. In terms of the other oil leaks, it turned out that one of the blanking plugs on the cylinder head (the ones you would remove to access chain tensioners I think) was completely loose and had unscrewed itself, only being held in by a bracket for the vacuum solenoids. The oil was then tracking along the top edge of the sump and ended dripping off of the bellhousing. So a simple tighten up resolved that, I then checked the same plug on the other head and that was quite loose aswell so I nipped it up too.
Other observations were half a socket set was sat in the subframe, previously dropped by someone several years ago - I would say about 5 years worth of rust on it! And many spurious m6 screws found jammed in the bracket at the top of the bellhousing which I assume got dropped there when the car had a new oil cooler gasket fitted by the dealership in a previous owners hands.
Also when the primary turbo was off I observed a loose bit of casting was blocking off the coolant supply to the turbo from the engine, so I poked a small screwdriver in with some grease on the end and pulled the bit of metal out. Glad I had the engine out to do this as I don’t think it would have been visible if it was still all fitted up in the engine bay.
The turbo oil feed tube was thoroughly inspected and cleaned (it previously had lots of instant gasket on the o rings), and was refitted with new o rings and copper banjo seals from jlr.
Next the prop received a new centre bearing, I chopped out the section of suspension air pipe where the previous join was and joined in a new bit of pipe.
Then the car was reassembled, gearbox oil topped up (I had previously disconnected the cooler lines to access the double drain mod better), front diff topped up, all fluids refilled, 2 worn lower ball joints replaced and she’s back in action!
It’s early days yet but all seems good, it pulls really well and it sounds good.
1 problem so far is a whining noise from somewhere under the centre console for the first mile or so of travel which then stops making any noise at all.. this I’m almost certainly sure is due to the cheap centre prop bearing I fitted.
So sometime I will revisit this and fit a genuine one.
Hope all of this is of interest / help to others
Post #588310 21st Mar 2021 7:38pm
t5pete
Brilliant write up, should serve you well after all that.
Post #588313 21st Mar 2021 8:07pm
GGDR
just wow
. Bow down Cheers, Greg
Post #588321 21st Mar 2021 9:04pm
Baltic Blue
I agree 100% Greg, but he is not working in the street or on his driveway.
Brilliant work though Thumbs Up Thumbs Up
Post #588322 21st Mar 2021 9:09pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I wish I had your facilities and your expertise to do the same to mine, just for peace of mind!
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #588335 21st Mar 2021 11:25pm
Edward
Thank you, as far as I can see, the main thing to look out for is oil consumption- if you are having to routinely add oil, and there is no visible leaks, there is a problem brewing. Even though there didn’t seem to be any visible side effects on mine, it probably would have ended up with a more serious problem - hydraulic lock or similar. So I’m glad I’ve got it sorted before anything like that happened.
Post #588345 22nd Mar 2021 7:13am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
oh to have the space and kit to do that!! i would do the same just because i can Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #588352 22nd Mar 2021 8:26am
DrRob
Nice!
What's the name of your garage? Good to know for others who might need your services Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588358 22nd Mar 2021 9:37am
Edward
Hi Dr Rob
We’re near Malmesbury in Wiltshire, if anyone is interested in us doing work for them, they’re welcome to PM me and I’ll forward our details Thumbs Up
Post #588421 22nd Mar 2021 4:28pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I absolutely love the casual nature of "I've got some oil loss so I thought I'd drop the engine out to have a look" as you do Rolling with laughter
Well done, nice to have facilities but it's still a very big job. I take my hat off to you sir. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #588460 22nd Mar 2021 7:27pm
Edward
Haha thank you!
Post #588502 23rd Mar 2021 7:18am
DrRob
Edward wrote:
Hi Dr Rob
PM sent Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588514 23rd Mar 2021 10:01am
pcourtney
PM sent
Post #711242 6th Feb 2025 4:45pm
