Home > In Car Electronics (L322) > Reset Info system
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Reset Info system
Try as I might I can't get information to display on the head unit (distance, range, mpg et), I also have lost the rotary volume control, the mode button displays the options but only radio is available.
The entertainment touch screen will display all options radio, cd, aux, tv as blacked in and available but when pressing the screen buttons I get the beep and the button changes colour (ie should be selected) however the thing remains on radio only.
Audio options screen is available and all options are selectable, harmon cardon etc and tone, balance, fader etc but none of them actually do anything.
Sat nav works, steering wheel volume works, steering wheel change track etc stopped working.
I have tested and checked every fuse, swapped relays over etc.
I have removed bluetooth module, checked MOST continuity in the boot, all modules, tuner, tmc, amp, out and return, even bought a bypass tester loop.
CD player has power and mechanically loads cd cartridge but I can't select CD and am stuck with radio only.
Dashboard display shows all correct info, time, date, c1 mpg, c2 mpg, range, temp etc, but head unit shows nothing.
MOST wakes up with orange flashing and splash screen, but then boots as normal (orange light off and into home screen options).
134679 and 753 won't allow me to get into self test mode with key at position 2.
I have also done countless 'hard resets'.
I'm stumped.
Any help much appreciated.
Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #555884 30th May 2020 10:27am
only a guess but the battery and alternator output could be checked. ... - .- -.
Post #556022 31st May 2020 4:39pm
RichM63
Cheers Stan, forgot to mention also changed in a brand new 110ah 920A battery. L322 3.6 TDV8 Vogue. 07MY
Post #556028 31st May 2020 5:14pm
Oddvar.L
Norway
I have wery similar issues with my car.
Did You find a reason for this behavour?
Post #565214 22nd Aug 2020 11:07pm
RichM63
Sadly no, I have not found a solution. Big Cry
So no music as yet. L322 3.6 TDV8 Vogue. 07MY
Post #565223 23rd Aug 2020 8:54am
Oddvar.L
Norway
To anyone with the same problems, I can report that the bug was in the TSD on my car. Got a used TSD from a breaker, changed over and all systems works.
Post #588126 20th Mar 2021 11:04am
DrRob
What's a TSD? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588133 20th Mar 2021 11:52am
Oddvar.L
Norway
Toutch screen display🙂
Post #588141 20th Mar 2021 2:31pm
RichM63
I shall bear this in mind. Thumbs Up L322 3.6 TDV8 Vogue. 07MY
Post #588176 20th Mar 2021 6:17pm
