![]() | Home > Technical (L322) > 4.4 TDV8 Rear Propshaft, can it be disassembled? |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 56 ![]() ![]() ![]() |
Just replaced my rear prop for an oe GKN part. The centre bearings available do not appear to be of good quality.
Geoff Hurst Member Since: 09 Oct 2021 Location: Sourhampton Posts: 10 ![]() ![]() ![]() |
I’m currently in the same boat which still doesn’t have a paddle! All advice gained is along lines of best to replace complete than fanny around, always seems to be the default answer. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The 4.4 TDV8 Propshaft is a two piece assembly and can be split easily (held together with a single bolt at the centre joint) so it's easy to replace just the bearing. Just make sure you get a genuine LR bearing and not an aftermarket one, as they're not as good as the original LR parts. |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Hi just took rear prop shaft of to replace centre bearing. No number for just bearing from landrover so ordered cheap one and will relace the bearing with good quality, well that is the plan . have removed the shaft assembly and loosened the bolt inside centre joint but several taps and the two shaft don't seem to want to part company is the a knack or is is just rusty tighty. |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 66 ![]() ![]() ![]() |
It's most likely a standard metric bearing. Take the old bearing along to your local SKF, FAG or Timken vendor, and they can very likely sort you out with an OEM quality bearing at a fraction of what LR would charge.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
More often than not it’s the rubber bushing around the bearing that fails rather then the bearing itself.
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 33 ![]() ![]() ![]() |
Hi, why is it “consensus” to replace the whole shaft instead of the bearing+mount alone?
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
Watch this to see what a hassle it is, personally I’d go for the GKN whole shift replacement
MattVogue44 Member Since: 20 Feb 2022 Location: Malvern Posts: 6 ![]() ![]() ![]() |
I replaced mine yesterday with a GKN which cost me less than £300 delivered, not bad as a one for a Dacia Duster 4X4 costs £325.
Hey Matt,
I could feel a thudding at low speed acceleration so checked central bearing, there was a lot of movement. My car has done 135000 so guessing original propshaft.
For information : Advanced Factors offer an online discount to forum members using discount code AF4LRP. https://www.advancedfactors.co.uk/lr030049...-1394321-p I’ve used AF for parts and found them very good. ( I have no association with them otherwise. ) I think the discount is 5% which may offset shipping to mainland Europe @Pal TDV8 4.4 2012 |
Thanks Ramblin man, will try to use them👍🏻 |
