![]() | Home > In Car Electronics (L322) > No gps signal (new antenna fitted) |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
No one have ideas ? |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Buy a cheap GPS puck with FAKRA connection off E*ay. Unplug connection at the sharkfin, connect puck and see if this works. If it does - faulty antenna indicated... but with option to mount the GPS puck and bypass the sharkfin entirely.
Thanks for the reply! I’ve already fitted a new shark Finn antenna and I’ve still got no gps signal I’m looking where else the problem can be ?????? |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 139 ![]() ![]() ![]() |
I have PDF file called " Densosat- Diagnosis" it might help you test or find your problem
Cheers pm on the way 👍 |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
You should be able to connect the FAKRA connector to the back of the unit as well, just in case that is easier for you. The nav unit searches for satellites, connects and stores a list in memory. If this list is depleted due to not being able to connect to anything, it can take a while to build up the information. When I had issues with my shark fin I tested with a £5 ebay gps aerial and found that the shark fin really struggled to find any satellites, but the £5 ebay one was markedly better. The original had likely been damaged by main dealer during a roof repaint, which was required thanks to paint damage done by Autoglass. (Such an annoying period of my ownership). Eventually the shark fin aerial was replaced by the main dealer, but it took a long time for the GPS to settle down afterwards. I live in a wooded area, that doesn't help, and cloud cover doesn't help either. Initially it could take up to half an hour to get rid of the red strike through line on the GPS icon. This was incredibly unhelpful if I was in a strange city and needed to find my way home (furthest I have been is about 2000 miles from home in it). Now, after some a few weeks it connects almost instantaneously. You can monitor satellite connections by entering the sat nav diagnostics using the 753 method on the sat nav screen. https://www.youtube.com/watch?v=fpf9o1V3B4U If you are picking up satellites, and usually 3-5 are required, then at least you know your aerial is connecting as it should. Mark |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
I had a similar experience when I changed the antenna on my RR. One thing to check, which might not be obvious, is that the satnav is still tuned to UK and has not defaulted to Belgium.
