Home > LPG > 4.2 SC on LPG cranks for ages & high fuel pressure |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 |
Hi David,
19th Mar 2021 9:32pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3137 |
Thanks John,
19th Mar 2021 9:33pm |
I’ve just been out for a quick run with it on LPG, if I stop it and restart it straight away it fires instantly. If I stop it, nip into a shop to pick something up and come back out, that’s when it turns over for what seems like ages but it probably around 5 seconds or so, maybe a little longer.
19th Mar 2021 11:06pm |
Hi David,
20th Mar 2021 12:36am |
Thanks John,
20th Mar 2021 12:45am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 749 |
Does it seem like it's "flooded" as we would have called it in the olden days?
20th Mar 2021 9:22am |
Cass,
20th Mar 2021 10:20am |
John
20th Mar 2021 1:49pm |
Well, there is a leak but it’s not an injector.
20th Mar 2021 7:27pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
You can most probably just change out the diaphragms, there's usually gasket kits available for most reducers, but if they're past their best probably just as easy to swap for new. |
20th Mar 2021 8:36pm |
I’ve rebuilt a couple of them in the past and have never had very successful results. They never seem to be able to maintain pressure properly afterwards.
20th Mar 2021 8:49pm |
Just to draw this to a close, replacing the reducers has indeed cured the prolonged cranking that I was experiencing on LPG.
27th Mar 2021 10:18pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 918 |
Holy Old thread revivel batman, I'm having a similar issue but getting low fuel pressure reading when switching from lpg to petrol causing the engine to stall out and engine mil light. Plus long cranking when starting on petrol after its been run on lpg. I'm interested to know about the vacum pipe connection mentioned in this post as I'm sure mine is teed into the vacum pipe at the rear of the supercharger and wondering if this is causing my issue.
20th Jun 2022 10:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8338 |
How old is the install,,? Pete
20th Jun 2022 11:39pm |
