Home > Maintenance & Mods (L322) > 4 Pot Brembo conversion.
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
Bl4ckD0g wrote:
Mikey wrote:
And if your going to upgrade to 4 pots, you may as well upgrade to 6 pots Thumbs Up
Thumbs Up Thumbs Up Thumbs Up
Totally agreed. One may as well...
But...In general I wouldn't do it at all. I would just stick to the basics and make certain my master cylinder and lines work well, my fluids are fresh, and my discs and pads are good. The braking power will be plenty to stop it. The bigger Brembo's are just well that, bigger. But also add extra weight most likely. And still don't give the sensation of super brakes anyway. I think it would be a waste of money project with very limited measurable benefit.
The six pot calipers are WAY lighter than the boat anchor two pot sliding calipers of the facelift 3.6. Stopping power seems vastly improved to me.
Post #587726 16th Mar 2021 10:12pm
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
I have. Six pots fit on a 2010MY (facelift with TFT instruments) 3.6 - you don't need the hubs.
I balanced with the rear brakes from a 4.4, too, as the rear discs are bigger - calipers, carriers and discs. All of the parts (apart from wearing parts) came from a donor 4.4 on eBay..[/quote]
Hi Briangunn.
Thanks for your info and good to hear you've already done the conversion. Can I confirm from your message that the rear callipers and discs are bigger also? Didn't want to misunderstand at this stage and could you give me a rough cost as I'm assuming you did it yourself?
Cheers and very best.
G
Post #587916 18th Mar 2021 4:29pm
briangunn
Yes, they are - I can't remember the exact figure (something like 18mm bigger diameter rings a bell). If I remember, the difference is just in the carrier and pads, the brake caliper itself is the same, but I'd managed to get a low mileage set of calipers so replaced the assembly..
Costs wise, I paid £75 for each side at the front, and £80 for each rear - these included the hubs and suspension parts too, from a breaker.
I bought new discs and pads all round:
Front pads £125
Rear pads £68
Front discs £130
Rear discs £120
Rear parking brake shoes £40
Sundries and fitting kits £20
The pad wear sensor at the front is different so you'll need one of those, too.
It all adds up, but my brakes were at the end of their life anyway, so it made sense to put the six pots on..
Post #587963 18th Mar 2021 10:25pm
Andy
I bought a pair of 4 pots from a 2008 TDV8 then found out they wouldn’t fit my 2010. I was told I need the 6 pot off the 4.4 or the 5.0sc.
For some bizarre reason they fitted the TRW callipers to the 2010 year only. Same ones as Jaguar I believe. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #588163 20th Mar 2021 4:00pm
GraemeS
See my post on page 1 of this thread....
Post #588196 20th Mar 2021 7:38pm
robster3.6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
grey17 wrote:
I contacted my local main dealer to get the gen straight from the horses mouth so to speak on the Brembo conversion and what parts are needed.
So, here is a definitive list with part numbers and prices. This is for a 6 pot Brembo conversion and it seems that all components are interchangeable or, no change or confusion about mountings and bolt holes. Copy and paste:
After a bit of research on my parts catalogue I can confirm the calliper mounting points, hubs and master cylinder are the same. The rear brake set up is mostly the same on both vehicles however the pads have a different part number. The parts required for a front conversion are as follows:-
Callipers- LR139257 & LR139255 -£779.33 Per Side + VAT
Discs- LR031845 -£86.10 Per Side + VAT
Disc Securing Bolt- SDG100000L - £0.90 + VAT (X2)
Pads- LR114004 -£276.53 + VAT
Pad Wear Sensor- LR012824 -£22.66 + VAT
Flexi hoses- LR075628 -£37.34 Per Side + VAT
Disc back Plates - LR011721 & LR011722 -£35.69 Per Side + VAT
Disc Plate Bolts- LR018509 -£0.66 + VAT (X6)
New mounting bolts- SYG500050 -£4.63 + VAT (X4)
The Flexi hoses are the same as those currently on the vehicle however I would advise if you do go ahead with the conversion to replace them.
Looks like a project for a little later the the weather warms up a bit!
G
This is great Grey! Sorry for the delay in coming back to this...
Which route are you going to go down with this?
Thanks
Rob MY10 L322 3.6 TDV8 Vogue
Post #588376 22nd Mar 2021 12:15pm
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I have found a good used pair of 6 pots which should be with me soon to start this conversion myself Cool 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #588380 22nd Mar 2021 12:35pm
