i recently had trouble with mine, had trouble turning the key on, once i had got the key to the start position, nothing happened.
i had 12.4 volts with the ignition turned off.
i didnt know where to start, i thought the ignition switch was on its way out.
i decided to start with the battery leads, they looked ok but i had to start some where
i soaked the terminals in a tin of water and wiped the battery terminals with a wet rag
a day later, i put grease on the terminals and battery posts
i now had 12.3 volts
turned the key no problem and it started straight away
been ok since RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
