Home > Maintenance & Mods (L405) > Under bonnet foam pads
i can imagine the cleaning bit to be fiddly ..
thanks for the info chaps.. ... - .- -.
Post #587668 16th Mar 2021 4:27pm
Tom_T
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Mine have gone as well recently so I’ll be adding replacing them to the long list of maintenance/repair jobs I’ve made for the spring 😂.
I was thinking of getting the front bumper sprayed as there are a few minor stone chips which were annoying me - then when I was parked outside my parents house recently their elderly neighbour reversed into the front of the FF so that made my mind up about that job 🤦‍♂️ Tom
2013 Causeway Grey 4.4 AB
2017 Ford Ranger 3.2 Limited
2016 Ford Focus RS
Post #587682 16th Mar 2021 6:02pm
fitted my rubbers today, took my time ..twas easy although a bit fiddly ..
used my special tool to keep the bonnet secure in its vertical position.
Post #591545 17th Apr 2021 6:08pm
Baltic Blue
Rolling with laughter We are now officially equally wooden Stan Thumbs Up
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #591547 17th Apr 2021 6:34pm
Mike, you do know there are little clips which make the bonnet stay up in service! Much safer than a noggin. I’ve got one of stans patent sticks..... I use it on my fork truck bonnet. Which is heavy and would actually remove ones noggin if it came down when your head was under it! There is nothing that can't be fixed with a hammer😜😜
Post #591550 17th Apr 2021 7:02pm
ah but my wood is longer than yours Mike Laughing ... - .- -.
Post #591553 17th Apr 2021 7:18pm
Wkr
United Kingdom 2014 Range Rover Vogue SE SDV8 Scotia Grey
Thanks to all for this topic and for info given. Ripped all mine this morning with the hard frost. More expense for a bad JLR idea. Great group. Happy new year to all.
Post #708468 6th Jan 2025 6:00pm
