Home > Maintenance & Mods (L322) > Jacking Up
Chris1573
Jacking Up
Any problem leaving the RR jacked up like this so that the suspension is hanging... I am doing some preventative rust removal and coating this week so it will be a few days...
Its on good 2 ton axle stands and also a pair of 10ton bottle jacks are nipped up under the chassis rail as back up. Front Wheels are chocked.
 L322 2007 TDV8 3.6
Post #587544 15th Mar 2021 12:05pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
I left mine up like that for a good couple of weeks when the brake pipes where being done and replacement flexis put on. I suppose you could put a bit of support under the wishbone so it's not at it's lowest extent but I didn't and nothing fell off or got broken.
(Well lots of other things are broken but totally unrelated to being left jacked up!)
Post #587576 15th Mar 2021 3:34pm
Chris1573
Thanks Stenh02 L322 2007 TDV8 3.6
Post #587579 15th Mar 2021 4:06pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Should be good too leave it like that but I'd also consider a trip too your local tyre centre and ask for a pair of decent size tyres like 265 plus. Wack them under the back. If the jack or the ground collapses it will land on the rubber tyre n hopefully prevent any further damage.
Just something I do if the car is being jacked up for a while
Post #587622 15th Mar 2021 9:59pm
Chris1573
Thumbs Up L322 2007 TDV8 3.6
Post #587641 16th Mar 2021 7:26am
