![]() | Home > Maintenance & Mods (L405) > L405 4.4tdv8 coolant leak head gasket? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Think the duplicate post got deleted that I was originally reading, and Blackdog replied to.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Hehehe although in different words I basically said the same.
BC1 Member Since: 20 Sep 2020 Location: Bucks Posts: 11 ![]() ![]() |
Thanks guys. I checked the water pump as that’s at the front and there is no way I could see how a pool could be created at the back of the engine from a leak there. I don’t know if the oil cooler or egr cooler sit on top at the back of the engine and could have a leaking gasket there? As I say there is pretty extensive staining at the rear of the engine. Is there any way o tell if it’s a HG? The car is 13 plate and no symptoms of HG but staining looks highly suspicious of something like that. Guess no way to determine an external HG leak? Eg chemical test of the coolant won show anything right? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 907 ![]() ![]() ![]() |
I would especially check the coolant hose that connects to the oil cooler on top of the engine - with a torch, you can just about see it on the right hand side under the inlet manifold / doughnut (viewed from the front) - any leak will drip into the ‘v’ and likely down the back of the engine. It has a rubber o ring that can perish. |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi Ben,
I’m not sure about the 4.4tdv8 but in the 5.0 the waterpump has got a connection at the back with a fairly brittle plastic pipe which when leaking can dump it into the V.
I can confirm it’s a 4.4 L405 I updated my profile. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
Ben, we have a workshop manual download in our wiki...might be worth looking at that? ... - .- -.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
for the cost of new gaskets and / or oil cooler you could start with that as having recently done my own there is significant water flow through it. I had oil leaking into the coolant and there are x2 coolant pipes that connect to the oil cooler. One of them has the usual clamp on it the other is a push fit with a spring to hold it in place. There is another post i read on here that that one has a O ring in it that is prone to going hard and leaking.
I had another look with the camera prove. Trying to get around the back of the engine from the passenger side this time. Looks like a build up on the bit of head gasket that sticks out. What confuses me is it seems that red staining and crystals along the cylinder head just above where the gasket is on both right and left cylinder heads. Does it seem plausible that both sides the HG can fail? |
I just tried the chemical test on the coolant reservoir and no colour change to signify any exhaust gases getting into coolant. So there is that and th garage told me didn’t really fail the pressure test. Yet it is definitely leaking and losing coolant and also there is a lot of red staining and pink crystals along the cylinder head just above the gasket line. Is there anything the garage can do to be sure before they start taking engine out? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi , I had a slight coolant leak on my L405 4.4 and while it was slight the issue would have developed. My issue was the thermostat housing which had a crack underneath the housing that was impossible to see without removal . Wasn't a huge cost and if your doing the oil cooler gaakets then this is a worthwhile check. 2015 4.4 AB
Sorry meant to say mine passed a pressure test too. 2015 4.4 AB
i cannot make up my mind where that is on the engine?? is it the outside edge or in the V?
